Old 07-09-2010, 01:14 PM   #1
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
AC Location
My Tradewind came with 3 vents two of which will be replaced with fantastic fans. I removed my old Armstrong AC and am going to get a new AC. I liked the look of the roof so much with out the front and rear vents and also minus the Ac that it got me thinking of locating the new AC where the middle vent is. I do realize that I need to still put in the stringers and cross braces. But doing it in this manner instead of original location would replace the vent that I probably would never use anyway and make for one less thing on the roof. What you think? Tried to edit and add pic but was unable. Will add .
SilverHoot is offline   Reply With Quote
Old 07-09-2010, 01:28 PM   #2
SilverHoot's Avatar
1967 24' Tradewind
Here's a pic
You can make out that the middle vent and the old AC were about 6 " apart. It would also mean that I would not have to make yet another 14' x 14" hole in the roof.
Old 07-09-2010, 01:52 PM   #3
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
What ever tickles your fancy,hopefully you can get your 110 volt back to it. Dave
easyride is offline   Reply With Quote
Old 07-09-2010, 02:00 PM   #4
SilverHoot's Avatar
1967 24' Tradewind
The 110 is easy since there isn't any wiring in it. I'll be rewiring it completely. Just went out and took a look at the ribs that the stringers would attach. The forward rib that the stringer would attach goes from the floor channel to about 2" above the entry door, so not a complete rib. The rear ribs that stringer would attach ends an inch or so from the sides of the vent.
Old 07-09-2010, 02:04 PM   #5
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Make sure that you run a drain line also.
Bill
Just my personal opinion
Old 07-09-2010, 02:23 PM   #6
SilverHoot's Avatar
1967 24' Tradewind
Bill
Thanks for the reminder Bill. Yes, I had thought of that and not hard to do with no interior walls.
Old 07-09-2010, 08:36 PM   #7
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
The only downside is that since at least some of the unit will be in front of the forward axle you'll pick up some tongue weight and it may not balance/tow as well as it did with the compressor over the axle. Might not be enough to be a problem but thought I'd mention it.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 07-10-2010, 06:29 AM   #8
SilverHoot's Avatar
1967 24' Tradewind
Thanks, I had thought of that myself. I may just end up cutting a new hole. Have not decided yet, probably wait until I have the AC. One thing that has me leaning towards cutting a new hole is the fact that the stringer at the vent location are not complete so I am concerned about structural strength.
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
jacking location Chip Arnold Jacks, Stabilizers, Lifting and Leveling 4 09-01-2008 10:00 PM
new a/c location ? twiggy137 Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-06-2008 07:55 PM
AC location - 1966 Forrest 1965 - 1969 Globetrotter 0 04-17-2004 09:07 PM
