Old 04-14-2013, 08:39 PM   #1
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
AC leaks when it rains.
Recently my AC has started leaking when it is raining. I have tried tightening up the four mounting bolts (still leaking) but I am afraid of over doing it. How can I tell how tight I can go without doing damage to the skin or frame as it is blind in that area and I can not see to tell.
MICHAEL
Old 04-14-2013, 08:51 PM   #2
Kyle401's Avatar
1969 27' Overlander
SW , Missouri
I just got done putting a new gasket on my AC to fix a leak. If you have a leak and the gasket is compressed to less than 1/2" in height, it's time for a new gasket.
When I replaced mine I found that the opening wasn't fully framed, so I fixed that while I was in there. On the older trailers, the original AC didn't have the same mounting configuration so if a newer unit has been fitted it's probably worth popping the bottom off to take a look.
Kyle401 is offline   Reply With Quote
Old 04-14-2013, 08:59 PM   #3
AWCHIEF's Avatar
Images: 33
Thank you. I will give it a look tomorrow.
MICHAEL
Old 04-15-2013, 07:11 AM   #4
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Hi, Micheal - We had our AC replaced by the boys at Out Of Doors Mart. It seeped a bit of moisture into the opening afterwards. They took it off and re-sealed the installation, as well as adding two bits of framing as Kyle said. Dry as a bone now.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 04-17-2013, 10:14 AM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
I recently replaced my A/C seal. The seal that the RV dealership (not an Airstream dealer) had in stock was a four-part seal that mitered together at the corners. Do these work OK or am I going to have to replace it with a one-piece seal?
Old 04-18-2013, 09:25 PM   #6
Kyle401's Avatar
1969 27' Overlander
SW , Missouri
The one piece seal isn't a molded gasket so it still has at least 1 glued miter corner. If the 4 piece gasket was properly assembled it should work.
Old 04-18-2013, 11:13 PM   #7
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
Check the AC drip pan... We had a leak when it rained and upon inspection there was a crack in the pan adjacent to the location of the drain tube attachment. A little 30 minute epoxy fixed the problem.
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 04-19-2013, 06:40 PM   #8
AWCHIEF's Avatar
Images: 33
Good suggestion but unfortunetly that is not where the water is coming from. It is obviously leaking from the outside when it rains. The crappy drip pan/drain issue is a whole different problem.
MICHAEL
Old 04-19-2013, 09:47 PM   #9
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
My TT is different brand, mount, etc, but for the OP I am of the opinion that the prolonged heat of our summers means maybe five years on the mounting gasket (cushion). Silver Streak used aluminum framing at the penetration, and I replicated the OEM mount by also using a gel cel aluminized tape (a couple of rolls) which appeared identical to factory underneath and wrapping over the opening (as I was R&R'ng the the original unit on two different TT's).
The latest TT seems to pull outside air (as interior humidity rises). OEM Dometic unit. You can bet I know what I'll find once I pull it off.
Good luck
Old 04-19-2013, 11:18 PM   #10
Scott J-24's Avatar
Bummer, thought I had that one solved ... I am confident you will pinpoint the problem and get it resolved.
WBCCI #1215
Air #54601
Old 04-20-2013, 05:06 AM   #11
1972 31' Sovereign
1979 29' Ambassador
west monroe , Louisiana
I can relate to your problem well. A PO of my camper had apparently placed his knees near the AC while doing something and I have two indentions right in front of the AC that puddle when it rains.
Last summer, I removed the upper shroud and discovered that the drain was clogged with debris. After cleaning this out, I had thought the leaking problem was resolved. However, after traveling in a drenching rain a few weeks back, I found my floor wet (not flooded).
The problem I've encountered is how to remove the bottom (interior) shroud in order to repair the indentions on the roof. Check out the drain. Can't really speak about the gasket as I haven't got that far yet.
litlgeezer is offline   Reply With Quote
