Old 11-22-2009, 01:30 PM   #1
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
AC Keep or replace?
My current AC shroud has been beaten to smithereens by hail and UV exposure. It sometimes ices up and has to be unplugged and defrosted to work. As near as I can tell its maybe 15-20 years old. Otherwise serviceable. There is a long list of other items I want to take care of as well but I have to have AC that works.
My question is should I put the money into a new shroud, or get one of the low profiles from Carrier before its to late?
Repair= shroud $105 + shipping and who knows what to fix the other issue.
Replace = $700 + shipping.
What do you think?
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 11-22-2009, 01:49 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
You want it come and get it
General,
If you find yourself back Estancia way I have an Armstrong shoud in decent shape. Your's if you want it.
They can also be fiberglassed. Up on the roof no one will notice it.
Old 11-22-2009, 02:17 PM   #3
MDSilverado's Avatar
1977 31' Sovereign
Severna Park , Maryland
Coil Icing
Icing is usually a result of low airflow across the evaporator (indoor) coil. Most often either dirty filters or coils are the culprit. I would say clean you coil and and see if you can get her to work properly. I was planning on replacing mine but once I saw how well she runs I decided to hold on to her. I have some slight damage to my cover and plan to fix by fiberglassing a patch form the inside and painting the outside.
MDSilverado is offline   Reply With Quote
Old 11-22-2009, 02:27 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I replaced mine this year with a LP Carrier 13.5K with heat strip.
My old Armstrong had a damaged shroud, the compressor did not run and the unit leaked water when it rained. It was an easy decision for me.
The new unit heats and cools very well, does not leak and the Low Profile looks great on a vintage unit.
Richard
Old 11-22-2009, 02:29 PM   #5
SSChanger's Avatar
Louisville , United States
Mine was 15 years old, had similar symptoms, then died in the heat of Summer. Cleaned the filters (an excellent suggestion), but 15 years of service is a long time for these units. Replaced it, and it was about $900 out the door, but the new unit works well and there are no worries next year. I just figured this was normal maintenance cost, and I still saved over $50K in buying a new or newer Airstream.
Good luck!
SSChanger
'94 Excella 1000; '03 Silverado 2500HD
Louisville, Tennessee
SSChanger is offline   Reply With Quote
Old 11-22-2009, 02:35 PM   #6
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
NOt a low profile but standard on ebay about $400
'77 Sovereign Intl 31' CB
Old 11-22-2009, 04:58 PM   #7
1972 29' Ambassador
Fort McCoy , Florida
Images: 16
Rodney,
If it were me, I'd buy the Carrier and part out the Armstrong on Ebay. I just got my 72 Armstrong working and was about to buy a new AC. But my shroud is still very nice and the unit is working fine and the parts to repair were $50. You could recoup $100+ "parting out", the old unit if you are lucky. Keep the Armstrong supports on your AS and use them for the new unit. You will have peace of mind even though some may say the Armstrong could run another 20 years.
Mrwaterway is offline   Reply With Quote
Old 11-22-2009, 05:52 PM   #8
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Follow up Qs
For a vintage 24ft: is the 13,500 large enough or is the 15,000 needed?
Go for the heat strip or pass?
What is the ducted upgrade?
Does the 68 Trade Wind have a drain tube? If not, how hard is it to thread one down between the skins?
Rodney
and the
My Blog
Old 11-23-2009, 04:37 PM   #9
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
bump
Rodney
and the
My Blog
Old 11-23-2009, 05:35 PM   #10
2002 25' Safari
Dewey , Arizona
Images: 62
I don't camp in Phoenix, but where I have used it (rarely) the 13.5K has worked very well on my 25' Trade Wind.
I purchased the heat strip for my Carrier LP. Recently in Fort Collins, Colorado it kept the trailer in the mid 60's when the outside temperatures were in the teens. I believe the current draw with the strip is higher then using the AC. It's a nice option when you have full hook ups.
This is for RV's that have cooling ducts to distribute the air. You would not need this option.
I believe you should have a tube installed from the factory. See if you can find it sticking out if the bottom of the trailer. On my 75 it exits street side just in front of the wheels.
Richard
Old 11-23-2009, 07:38 PM   #11
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
My 68 has a drip tube from the factory a/c that runs down along the edge of the cabinet next to the stove.
Old 11-24-2009, 04:45 AM   #12
1984 31' Excella
Norfolk , Virginia
Images: 11
Ac
AC should never freeze for any reason if the charge is right.
The reason you get frost on the evaporator coils is because the refrigerant charge is low.
Refrigerant like propane or butane has a pressure/temperature constant.
What this means is that when the material (refrigerant or bottle gas) is at a certain temperature it will read a certain pressure.
With the closed loop that an AC is when the refrigerant is low the temperature of the evaporator coil (the inside one ) will be running at a temperature below freezing and frost/ice will begin to accumulate.
You should always keep the coils clean (both inside and outside) to minimize the loading on your compressor and to allow maximum efficiency.
Beginner
Beginner is offline   Reply With Quote
Old 11-24-2009, 10:55 AM   #13
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
My vote / or opinion
a. Get a new shroud.
b. Clean the coils(both of them)(Spray-n-Wash helps).
c. Freon(but I doubt it needs any).
You have all winter to attend this chore.
kennethowens is offline   Reply With Quote
Old 11-24-2009, 11:09 AM   #14
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
After going back and forth on this I finally decided to just get the new one. Part of the finial decision was that while I am in TN I will have the tools and equipment to get the job done.
Carrier 13,500 BTU with heat strip $717.99 delivered.
Rodney
and the
My Blog
7.00-15....what would you replace them with? aircooled4 Tires 13 01-16-2017 07:39 PM
replace AC? roguebrun Furnaces, Heaters, Fireplaces & Air Conditioning 6 10-29-2008 06:09 PM
What if anything do I need to replace? RWinward General Repair Forum 2 08-12-2008 01:42 AM
Need to replace this - but what is it? Tom Randall Phone, CB & Ham Radio 10 05-22-2007 10:40 AM
replace 10 by 6 by WH CatandMe Water Heaters, Filters & Pumps 0 06-24-2003 12:16 PM
