Old 04-21-2010, 08:00 AM   #1
1978 28' Ambassador
Savannah , Georgia
AC insulation
Took apart the cover to the 32yo Armstrong AC. There was 1/4" fiberglass insulation glued to the inside of the cover. The insulation held water and this allowed rust to form on the galvanized metal. Scraped and painted the metal. Where can I find 1/4" sheets of insulation? Found 1/8" foil backed insulation at HD. Can this be used instead? And as an added surprise, found out there is a heat strip coil! Thanks. Jack
Skamper1 is offline   Reply With Quote
Old 04-21-2010, 03:21 PM   #2
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
be careful with the cover, if it is anything like mine, not fiberglass but plastic and breaks with any pressure, also A/c people thought 4 well placed screws were enough to hold it in place. I managed to put 4 more in as two of the screw holes had cracked and probably would have let loose with an 18 wheeler passing. Always wondered why I saw a lot broken covers on the side of the road. ;-(
Old 04-22-2010, 05:27 AM   #3
1978 28' Ambassador
Savannah , Georgia
The shroud is another project. Mine was vulkemed all around the bottom to the roof of the AS. It has three cracks and many more along the bottom edge. Plan to use pieces of aluminum 1/2" flat bar to beef it up. A new shroud is around $250! I am working on the inside cover of the AC itself. Found a roll of foil backed insulation. May have to use two thicknesses. Jack
Old 04-22-2010, 11:24 AM   #4
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Insulation?
I am trying to figure out why there is insulation on the inside of the cover.
Is it just to protect the plastic cover?
Ken
Old 04-23-2010, 05:31 AM   #5
1978 28' Ambassador
Savannah , Georgia
This is the housing/chamber after the compressor. There is a heat strip there and I assume an evaporator. Not my area of expertise, so may have to ask others. Maybe it is there to help heat the "winter" air? Just know I am scraping all visible rust and giving it a paint job before resealing the AC. Managed to take apart shroud. Getting good at removing rivets. Now if I can get good at reinstalling them! Jack
insulation angelapratt Ribs, Skins & Rivets 1 11-08-2009 01:13 PM
Insulation S&L Buyer Guidelines 2 04-28-2006 07:17 AM
Insulation C Johnson General Interior Topics 22 04-30-2005 02:12 PM
Re-insulation pbt45 Commercial Listings 1 02-27-2004 10:25 AM
Insulation Cat General Interior Topics 6 11-26-2002 06:31 AM
