Old 03-22-2016, 09:24 AM   #1
1969 18' Caravel
Centennial , Colorado
AC Installation cost
Yikes! The Airstream dealer in Denver just quoted me $1475 for a new installation, not a replacement. I already have the AC unit and the distribution box. Seems a bit spendy to me. What do you folks think?
GRussell is offline   Reply With Quote
Old 03-22-2016, 10:10 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
The 2 unknowns that may be in play and greatly increase the cost are. Is it prewired and is a drain tube preinstalled?
2004 Excursion 4x4
Old 05-19-2017, 05:06 PM   #3
Fort Lauderdale , Florida
I am thinking about getting an AC system installed as well. Currently, there is none. The model is 1970 23' Safari. Does anyone know if the model is pre-wired and has a drain tube? If they have to be installed for the system, how would one hide them? I do not want to see a wire and tube running on the ceiling or roof. I heard that the hole is usually reinforced with wood frame to support the AC unit. How much would this work typically cost?
writemate is offline   Reply With Quote
AC installation (recommendations and cost) Professor Furnaces, Heaters, Fireplaces & Air Conditioning 0 06-07-2012 12:02 PM
Cost for Hardwood installation nautiqueman Floor Finishes 7 12-08-2010 09:31 AM
cost of 50 amp installation Armur Electrical - Systems, Generators, Batteries & Solar 6 06-13-2007 06:45 PM
Cost for a new 454 motor including installation? bugsbunny Airstream Motorhome Forums 6 11-11-2003 07:13 AM
