Old 01-31-2009, 04:36 PM   #1
mikmilr's Avatar
1964 24' Tradewind
Swoope , Virginia
ac identification
I am wondering what kind of ac unit is in my 64 tradewind. I haven't had the top shroud off yet. Inside I have a wall mounted thermostat separate from the furnace control. I also have a toggle switch on the side of the unit with low, high, and off. The fan is visable from below and there appears to be a 2 piece evaporator, frontward and rearward of the fan. I am sure this is original because there are instructions on the inside of the ward door that mention the toggle switch. Was there anything used besides armstrong ac for that year?
Thanks, Mike
mikmilr is offline   Reply With Quote
Old 01-31-2009, 04:40 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
My 62 is Dometic. It looks like a big cube thing.
Old 01-31-2009, 08:05 PM   #3
Thanks, Mike
If it has a round intake filter at the bottom of the inside pan, then you have an Armstrong AC, model # TAC-110, and it has a 10,000 btu output, when working correctly.
Old 01-31-2009, 08:19 PM   #4
mikmilr's Avatar
1964 24' Tradewind
Swoope , Virginia
Thanks Andy. It looks like it had a round filter. I read that the armstrongs are still servicable. Is that round filter still available or will I have to make something?
Mike
Old 01-31-2009, 09:44 PM   #5
Mike
Mike.
The original filter was a foam material, that was sort of thin, like a cheap air filter, and it was only 1/4 inch thick.
That AC is good, and can still be serviced with ease.
Toilet Identification wlgilbert40 Sinks, Showers & Toilets 5 04-29-2008 01:14 PM
Wiring identification help needed crdouger Batteries, Univolts, Converters & Inverters 7 03-18-2008 08:32 PM
Coach Identification luckydc Airstream Trailer Forums 15 01-23-2007 07:27 PM
Need Identification help Gambit242 Airstream Trailer Forums 16 08-30-2006 09:26 PM
VIN Identification trogers713 1970 - 1973 Sovereign 6 06-15-2004 04:55 PM
