AC help please
I have tw0 thermostats in my AS. one is in bedroom and one is on wall by fridge in living room. Can someone explain workings of both and if I can change out thermostat in front room seems to be in bad shape. Do not use furnace scared of it and just really havent messed with it so I use plug in heater. . Also when I turn on fan switch on overhead AC ,compressor kicks on and then off and back on and runs good after that just thermostatic controls are dicey so it gets like 20 degrees at night might as well be inside a fridge. Thanks for any answers. AS is parked in one place as second home for last 5 years with roof over use on vacations. the one in bedroom is called Suburban and has controls the other only has lower slide controls and 2 wires in. Thanks for any help.
