Old 07-15-2019, 02:55 PM   #1
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
AC help needed
Our AC in our 2012 will not keep running, the compressor runs about 30 seconds then shuts off with an E7 error message in the control panel. The first time it happened the breaker in the unit tripped but that has not happened again. When I called our dealer( 5 hrs away) they thought it might be a control board in thermostat unit on wall. Living only 30 miles from Jackson Center I went and got a new control panel. The new panel did the same thing as the old. I have tried running on generator only since it is so hot here in Ohio thinking maybe not enough power was available, no difference. Any ideas?
Castaway is offline   Reply With Quote
Old 07-15-2019, 03:02 PM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
E7 error is power interruption. Do you have a surge protector installed?
Dept of “OverKill”
Old 07-15-2019, 03:15 PM   #3
Castaway's Avatar
Celina , Ohio
The power is coming from our house or directly from a gennerator that has run the AC in the past.
Old 07-15-2019, 03:28 PM   #4
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
What about the 12 volt side. Converter working ok. Batts good. Thermostat is 12 volt.
Dept of “OverKill”
Old 07-15-2019, 03:39 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Would it give E7 code if the start capacitor is bad, not providing the proper boost to get the compressor going?
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 07-15-2019, 04:16 PM   #6
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Probably not. Maybe the run cap, but in order to get an E7 error code there needs to be a power interruption to the main board.
Dept of “OverKill”
Old 07-15-2019, 05:38 PM   #7
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Could be a bad breaker. Cycle it several times. Check to see if it is warm right after the AC shuts off.
Also, measure the voltage in the trailer when the unit is running. Should be at least 110V for good operation. Anything under 100 is bad news.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 07-15-2019, 07:33 PM   #8
Castaway's Avatar
Celina , Ohio
Well, after reading all of the advice I got here and Facebook I started troubleshooting the electrical pathway. The first thing I did was take emery cloth to the male plug ends. When I tried running again it WORKED!!!!!!! I will try tomorrow when the outside temp is over 90 again since a storm cooled the air to 74. Thanks for all of your help.
Old 07-15-2019, 07:40 PM   #9
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
After doing some research Sounds like run cap
Dept of “OverKill”
help, help, help. new to it all. ohwally Member Introductions 5 08-24-2008 04:18 PM
HELP HELP HELP!! Lug nuts & Stems Chitown AirStreamers Wheels, Hubs & Bearings 4 08-18-2008 04:41 PM
Hot Water Heater HELP HELP HELP!!! Igor68 Water Heaters, Filters & Pumps 2 06-22-2006 08:07 PM
Help Help Help!!! rebel beck 1974 - 1979 Sovereign 9 01-07-2006 03:00 PM
