Old 06-08-2013, 06:57 AM   #1
1973 31' Sovereign
Charleston , South Carolina
AC Help
I am replacing old Armstrong on a 31'
I just want a cool only Penguin 13,500
What is the difference between ducted and non ducted units.
Which controls?
Thanks.
Jim.
cuyd is offline   Reply With Quote
Old 06-08-2013, 07:05 AM   #2
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
Which controls?
Thanks.
Jim.
A ducted AC is normally found in Motor Homes or big Trailers that have room in the ceiling to run ducts for air distribution. Your Airstream will need a non-ducted AC.
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 06-08-2013, 07:17 AM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Which controls?
Thanks.
Jim.
You need a non-ducted unit, since Airstreams do not have the required ceiling depth and headroom for a duct system that distributes the cool air thru out the trailer. I would also get a 15K unit for a 31', as you will appreciates the extra cooling capacity when it is either very hot or humid.
Next to consider are the cooling controls. You have 3 choices:
• direct mechanical controls: these are 2 rotary knobs located on the bottom of the air distribution box at the bottom of the A/C unit, one for fan speed and the other for degree of cooling. There are no precise temperature settings on this type
• single zone digital thermostat: a small box mounted on the wall that gives you a digital read out of the actual temperature that has been set and the actual room temperature. You can also control your furnace with this device. NOTE: this requires 12VDC wiring to be present at the A/C unit in the ceiling and 3 minimum 18AWG wires to run from the A/C to the thermostat location. You also must have the two blue wires from your furnace present at the A/C location if you wish to run the furnace.
• Comfort Control Center II (CCC II): a more complex digital thermostat system that has multi-zone capabilities. All of the extra wiring stated above must be present for it to work, plus there must be an RJ-45 phone-type data cable run between the A/C unit and the CCC II.
For ease of installation, most folks use option 1. If you are doing a re-model or have the existing wire in place, options 2 or 3 make for a better installation.
Old 06-08-2013, 07:46 AM   #4
1973 31' Sovereign
Adonh, Lewster
Thanks for clarification
Option 1 will work
Thanks.
Jim.
Old 06-08-2013, 08:00 AM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
#31 footer with a 13,500 will be a real challenge....especially in a southern climate....impossible in a Texas climate.
Old 06-08-2013, 08:59 AM   #6
1973 31' Sovereign
What model # is the 15,000 cool only Penguin with controls on ADB
Thanks.
Jim.
Old 06-08-2013, 09:19 AM   #7
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
According to the guy who sold us our 15000 BTU unit last year at an AS dealership, the 15000 units must be thermostat controlled: there's no "on the unit" controls for these for the Penguin II. Ours is a cool only unit also and we are happy with it.
Kay
Old 06-08-2013, 09:57 AM   #8
lewster's Avatar
Penguin II high capacity ( 15K) Cool Only: # 641916 (Single Zone Thermostat required) MSRP: $959
Single Zone Thermostat: #3313189.000 MSRP.............$98
ADB for Wall Thermostat unit: #3310742.014 MSRP................$129
The dealer is correct! After checking with my reference material, you can only use the mechanical controls with the 13.5K model #640315 MSRP.....$801
ADB with mechanical control: #3310741.016 MSRP........$129
The difference being that the 15K unit already has the electronic control board installed in the unit, where the 13.5K does not, allowing it to use the mechanical controls.
Hope this helps.
Old 06-09-2013, 09:33 AM   #9
1973 31' Sovereign
I am in SC.
Where can I buy A new Penguin unit?
Thanks.
Jim.
