Old 09-15-2016, 08:21 PM   #1
1976 29' Ambassador
Atlanta , Georgia
AC/Heat pump unit instead of furnace?
I'm looking at some AC unit and found one from Dometic that is an AC/heat pump combo unit.
We live in GA and we don't plan to camp when or where it's cold. I have upgraded to 50 amp service (220v/50amp), although I understand that some campsite will only have 30amp service. Would this is sufficient for early Spring and late Fall chill without installing a separate furnace?
Chae is offline   Reply With Quote
Old 09-15-2016, 08:29 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I use the heat pump to take the chill off down to about 40 degrees. Below that it does not work well. Below heat pump range us the propane heater or if plugged in a small portable electric heater.
MICHAEL
Old 09-15-2016, 09:42 PM   #3
1979 23' Safari
Wayland , New York
Heat pump will do ok down to about 40f as mentioned. After that small ceramic heated work well. Sounds like you'll have plenty of juice. Plus if you're plugged in and electric is included it's free, no propane. Just look out for below freezing temps if you don't have tank heaters, consider adding tank heating pads.
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 02:18 PM
Air C/Heat P Dometic instead of Furnace? Donnagoes Furnaces, Heaters, Fireplaces & Air Conditioning 5 04-07-2015 03:14 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
