Old 06-27-2006, 10:10 AM   #1
Over59's Avatar
Putnam , Connecticut
Images: 37
AC Guru 141 Volts
Ok, so maybe it's OK. The little three light thing has the red and center yellow light on for both GFI circuits but not the Air Cond circuit. I know they are wired right at the recept. Cann't imagine it's wrong in the AC panel. It's marine so it is a little different. The test trips the GFI's .
I am getting 121 across the Neutral and Hot, 11 across the Neutral and ground, and 141 across the Hot and Ground on the first GFI. I'm running a Honda 2000.
What gives?
Over59 is offline   Reply With Quote
Old 06-27-2006, 10:39 AM   #2
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Generator
Paul,
What is coming out of the generator?
Rob
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 06-27-2006, 10:56 AM   #3
Over59's Avatar
Images: 37
Hot Ground 12V (yes from the 120 recept) Hot Neut 122V and Neut Ground 0
Need an Electrical Guru Mookie Electrical - Systems, Generators, Batteries & Solar 13 05-31-2006 07:45 PM
The Polishing Guru Open House & Rally zinbar Other Rallies & Events 0 05-24-2006 05:06 PM
Open house at the Polishing guru zinbar Other Rallies & Events 0 05-21-2006 04:13 PM
115 volts on a 1982/3 310 MH Chuckles Airstream Motorhome Forums 4 03-08-2006 05:36 AM
"univolt" Chuck Electrical - Systems, Generators, Batteries & Solar 10 06-07-2002 01:30 PM
