Old 09-30-2017, 07:18 PM   #1
HCR
HCR's Avatar
Livingston , Full time traveler
AC fan runs, compressor doesn't
title says it all.
Advice?
Airstream of Consciousness
HCR is offline   Reply With Quote
Old 09-30-2017, 07:39 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Capacitor.
Air conditioner assembly.
Old 09-30-2017, 08:17 PM   #3
HCR
HCR's Avatar
Thanks, that's what I was thinking.
Old 09-30-2017, 08:23 PM   #4
2010 30' Flying Cloud
fredericksburg , Texas
Ac
Mine did same thing on my airstream turned out to be some little part that was about $120 I could hear water gurgling in the inside and it was not draining out properly - I question if it got something wet. If I turned system off few hours it would cool a few min then only fan would blow. I live in a rural area and service guy had to come twice. My bill was about 480 total but about 100 was for trip. Charge the line had to be blown out and the part replaced. Donít panic I donít think itís the whole unit. Good luck
Short something out
fbgairstream is offline   Reply With Quote
Old 10-02-2017, 02:48 AM   #5
1964 26' Overlander
Palmyra , Virginia
May also be main relay that controls compressor
Scoutx is offline   Reply With Quote
Old 10-02-2017, 05:33 PM   #6
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Or thermostat is not calling for cooling. I had a busted thermostat on my Coleman Mach 8 with that same symptom. Was able to jumper the thermostat contacts to get it to kick on, which gave me my diagnosis.
TheGreatleys is offline   Reply With Quote
Old 10-03-2017, 08:27 AM   #7
HCR
HCR's Avatar
It wasn't the capacitor!
Before buying a new capacitor, I called a local AC tech--not a specialist in RVs. He climbed on roof, removed cover and at once discovered a pin size hole in a copper line from which Freon had escaped. Welded hole, attached valve and refilled Freon.
total cost: $100. Of course that's because I'm parked in Zapata, TX where prices for all labor are lower.
Thanks to all of you who responded!!
« shb2777 | Top | 2017 fc27fb »
water pump just runs but doesn't suction BessieB Plumbing - Systems & Fixtures 11 02-26-2016 01:55 PM
WaterPump Runs but Doesn't Pump Dreamnair Water Heaters, Filters & Pumps 10 10-10-2015 07:49 AM
Compressor runs but needle doesn't move! ericjan2 Classic Motorhomes 6 10-23-2012 04:34 PM
AC Fan runs, compressor does not turn on JW84345 Furnaces, Heaters, Fireplaces & Air Conditioning 8 07-06-2009 04:37 PM
WBCCI- Doesn't listen or just doesn't care Stream 1529 WBCCI Forum 30 09-29-2008 04:55 AM
