Old 04-05-2007, 06:32 PM   #15
lewster's Avatar
Naples, FL , Hood River, OR
Nick,
Actually, that foam gasket found on the bottom of all roof airs should be tightened to a COMPRESSION of 50-60%, according to the Dometic spec. It's function is to seal the unit to the roof and thus not allow water to penetrate it. It's original intended purpose was not as a shock absorber, but a water tight seal.
Old 04-10-2007, 11:47 AM   #16
Free A/C salvage
My old dometic is up for grabs as salvage. the shroud and all parts except for the compressor are still in good condition. if anyone wants to pick it up, I live in Ellijay Ga. and there will be no shipping. Its not much to work with but its Free!
Rick
0557 is offline   Reply With Quote
Removing Belly Pan garp Belly Pans & Banana Wraps 5 07-06-2016 12:48 PM
Question on AC Drip Pan bjond Furnaces, Heaters, Fireplaces & Air Conditioning 1 12-27-2006 12:53 PM
Water Tank Pan Craig Fresh Water Systems 7 09-06-2002 08:52 AM
Water Drip uwe Fresh Water Systems 6 07-11-2002 08:39 AM
Camping World - No A/C Pan? ViewRVs Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-25-2002 08:55 AM
