Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 10-20-2003, 07:25 AM   #1
Tin Hut's Avatar
Profile:  2005 28' International CCD
Southlake , Texas
AC drip hose
Just had an AC installed and could not run the drip tube down inside the walls without pulling off a bunch of panels. Now the water runs off the outside. A friend recommended a novel idea of taking a drain tube from the drip pan and running it to the adjacent sink vent pipe coming from the roof. Drill into the side of the pipe, thread the tube down a ways and then the drip runoff from the AC goes down the sink drain. Before I try this has any one had experience with this or any other advice? I'll secure the tubing on the roof so it doesn't move in transit. Thanks.
Tin Hut is offline   Reply With Quote
Old 10-20-2003, 08:25 AM   #2
Profile:  , Minnesota
Images: 59
Airstream Registry
Drip tube
Great idea.
Check carefully with a water hose to make sure vent is actually connected. When I took the walls out of mine I found the vent pipe had come loose (or was improperly connected in the first place) at an elbow inside the wall. If that happened in your unit you would have a slow water leak for a long time before you knew about it.
Old 10-20-2003, 08:30 AM   #3
Profile:  Corona , California
JFSJR
Your idea will work OK, provided that the cap on the sewer outlet is "off".
If the cap is secured, the drain water from the AC will start coming up in the bathtub.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
AC Gasket replacement Sneakinup Furnaces, Heaters, Fireplaces & Air Conditioning 3 11-30-2003 09:07 AM
Fridge doesn't work on ac jwaldin Refrigerators 5 04-10-2003 10:38 AM
Coleman AC Heater Element Pick Furnaces, Heaters, Fireplaces & Air Conditioning 4 12-02-2002 02:04 PM
Yukon AC cuts out towing.... dscluchfc On The Road... 10 07-27-2002 11:01 AM
Water Drip uwe Fresh Water Systems 6 07-11-2002 08:39 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
