Old 04-28-2006, 08:07 PM   #1
Canuks's Avatar
AC drip,drip,drip,drip,drip
How does the condenced water that collects on the AC coil escape from the factory installed air conditioning unit? Does it have a drip tube that runs between the inner and outer shell? Or does it just run down the outside?
I just had to rebuild a high quality de-humidifier that had drip tube issues. It ran for a few days unattended dripping water before it was noticed. It got me thinking that a clogged AC drip tube could cause some problems
Canuks is offline   Reply With Quote
Old 04-28-2006, 08:32 PM   #2
bill benton's Avatar
Mansfield , Texas
Yes the drip tube runs out the bottom of the trailer. Sometimes you can clear it with a blast of air.
bill benton is offline   Reply With Quote
Old 05-07-2006, 06:52 AM   #3
Canuks's Avatar
Thanks for the reply. I will keep an eye on it.
Old 05-07-2006, 10:06 AM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Typically there is a hose in the streetside wheel well (newer Airstreams).
Old 05-07-2006, 04:04 PM   #5
1960 24' Tradewind
Riverside , California
Drain Hose
Blow a string thru the tube from the top down, then tie a small piece of rag to it and pull it thru, thats how we clean them out.
Zoom
ZoomZoom is offline   Reply With Quote
Old 05-29-2006, 12:35 PM   #6
sovereignrwe's Avatar
2020 30' Flying Cloud
1995 25' Excella
Clear Lake , Minnesota
Can't tell the year of your trailer, but for the older trailers that have an Armstrong, I can get to the drain tube from inside the trailer by removing the street side filter.
Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
sovereignrwe is offline   Reply With Quote
Old 06-02-2006, 02:05 PM   #7
BURNZEE's Avatar
Riverside , Missouri
Anyone know where the tube would exit on a 66 Safari International. I've been all over it and can't find it anywhere.
BURNZEE is offline   Reply With Quote
