Old 08-31-2015, 06:57 PM   #1
DeltaRon's Avatar
2015 28' Flying Cloud
2018 33' Classic
Cumming , Georgia
AC drainage
2015 FC 28. Hot day in south LA. AC draining as normal in wheel well. For first time, however, I have some water also draining from the rain gutter on top toward front of trailer opposite entry door. It is dripping along outside skin by window. Is this normal? Or is there some other pending problem?
DeltaRon is offline   Reply With Quote
Old 08-31-2015, 07:32 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have the same problem. Definetly not normal. I suspect my drain hose is clogged. Going to see if I can blow it out tomorrow.
MICHAEL
Old 08-31-2015, 07:52 PM   #3
DeltaRon's Avatar
2018 33' Classic
Cumming , Georgia
How do you blow it out?
Old 08-31-2015, 08:19 PM   #4
AWCHIEF's Avatar
Images: 33
Stick a high pressure air nozzle in the end of the hose and blow. Should not have to be to high to work. Start off slow and build up the pressure.
MICHAEL
Old 08-31-2015, 08:42 PM   #5
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Go easy with the volume of air... If the condensation pan is full to overflowing and draining from the sides, when you put the air to it you will clear the line and you could blow the water into your coach. I was able to clean my Armstrong 14 by removing the cover and getting at it the source. I cleaned a bunch of gunk that I wouldn't have otherwise blown into the condensate pan. It was really easy and enjoyable to fix.
NavyCorpsman is offline   Reply With Quote
Old 09-01-2015, 11:52 AM   #6
AWCHIEF's Avatar
Images: 33
My AC unit was replaced just over a year ago at Jackson Center. Pulled the interior cover off to access the drain so that I could clean it out because of water running down the side of the trailer. Made an interesting discovery. The drain line is there but not attached to anything. As far as I can tell I have no drain pan. That explains why the water run off. Now of course I am confused as to what my next step should be.
Name:	ImageUploadedByAirstream Forums1441129836.567267.jpg
ID:	246989Click image for larger version
Name:	ImageUploadedByAirstream Forums1441129851.557828.jpg
MICHAEL
Old 09-01-2015, 02:53 PM   #7
1979 23' Safari
Wayland , New York
Attachment 246989Attachment 246990
If the water running down the side doesn't bother you to much you can leave it. Other options would be lifting the ac to install a drain pan or the drain cups.
Old 09-02-2015, 07:44 AM   #8
AWCHIEF's Avatar
Images: 33
It is more a nit picking annoyance than anything else. It looks like all the water is going outside. Not really something I want to spend a lot of money on right now plus I physically do not think I am able to safely remove the AC top end unit by myself. I am very aware of my backs limitations. After I win the lottery I can deal with it if really necessary. What does bother me is that the new AC was put in by the Airstream factory and they did not install the required drain parts. I am going to give them a call and see why not.
MICHAEL
Old 09-02-2015, 08:34 AM   #9
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Source of Dripping Water
PLEASE don't blow on your drain hose, get a wet-dry vacuum and suck the crud out. You're probably growing algae and mold on the inside, and you don't want any of that to end up inside your A/C. Of course if you're cleaning the air filters at the same time you could spray the crap all over your living area. You don't need a nozzle that fits the diameter of the drain hose, just hold your fingers over the end of the vacuum leaving a small gap for the drain hose. We do this at the office about twice a summer.
You might also simply walk outside at 2 AM and look at the outside of your Airstream. Mine will have condensation everywhere on the roof because the A/C is running and the humidity is always +90% in eastern Virginia in the summer. Roof condensation could be what is running down the sides. If some moisture is coming out of the drain hose then roof condensation is the obvious culprit.
In extreme summer I've had it dripping INSIDE - but that happens if I forget to turn on the shower fan when bathing. I'm sure not tempted to make any hot meals inside during summer, and I've steam cleaned the whole inside once just by going to the truck for a few minutes and not hearing the teakettle start to whistle.
Old 09-02-2015, 09:46 AM   #10
2019 27' Globetrotter
Missouri Valley , Iowa
I was told that condensate water running down the side of your trailer will eventually etch it.
Dan
Farmer Dan is offline   Reply With Quote
Old 09-02-2015, 10:48 AM   #11
Old 09-02-2015, 11:57 AM   #12
AWCHIEF's Avatar
Images: 33
Foiled, curious why the second identical post?
MICHAEL
Old 09-11-2015, 10:04 PM   #13
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Any word from Airstream? When Airstream replaced you AC did they install the dreain cups vs the drain pan. Did they install a Dometiv Penquin or another brand that drains externally. I've read somewhere on this forum that if the drain cups overflow due to heavy humidity the drain to the outside.
Kelvin
Old 09-13-2015, 09:30 AM   #14
AWCHIEF's Avatar
Images: 33
AC drainage
Kelvin, yes they called me back and emailed a copy of the work order. It simply says "4/17/14 new AC with heat pump new thermostat, n/c warranty total 1219.00". He said there was a Dometic recall for coil/gas leakage and they swapped out about 20 units around that time and occasionally still get one in. I mentioned the drain line not connected and he said it is designed to drain outside, drain cups could be installed if desired but are not necessary. He had no additional information.
MICHAEL
ABS drainage system - 2005 Classic RoadToad 2001 - 2005 Classic 16 01-29-2009 01:36 PM
Urgent vintage grey water drainage question! 1959newbie Waste Systems, Tanks & Totes 6 04-21-2007 09:58 PM
Water Tank Drainage popeyedoyle1 Fresh Water Systems 8 03-07-2006 04:50 PM
16' ccd Bambi drainage system question. gbrentsmith Waste Systems, Tanks & Totes 12 10-17-2005 09:08 PM
