I have an 84 310 Limited Motor home. The two roof air conditioners seem to function fine. Unfortunately there were leaks between the drain pan and the roof. A fellow who was working on the MH tried to remove the ACs to re-seal them but he drain pans had been attached to the roof with an adhesive which had hardened and the pans were destroyed in the process of removal. So, I have functional coleman ACs but no drain pans. The local Airstream dealer and Inland RV says the drain pans are NLA.
Any suggestion?
Anyone know of a source for the pans? Or, specs for the pans so that I could fabricate them or have them fabricated?
"btdt" not much you can do . i looked for the pans also for a couple of years .
as andy stated nla . i finally replaced my colemans with dometic penquins. those pans are available. the colemans were fried by virginia power.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
