Old 07-11-2006, 06:51 PM   #1
acrane's Avatar
1980 31' Excella II
Stonewall , Mississippi
AC Drain Location Under Shroud?
Well we paid all that money for both manuals and they do no show the ac or it's drainage system.
We took the shroud off, cleaned out, blew air pressure up the line, could
hear noise but not feel air. Could not find opening in unit (on top of trailer)
where water drains down.Do you have anything or can you tell us where the
opening is. We have tried clearing it from the bottom of the drain underneath edge of trailer with a 50 foot metal thing like a drain cleaner, we
have tried air pressure (125lbs) non of this is working. HELP!
Alice Crane
acrane is offline   Reply With Quote
Old 07-11-2006, 06:57 PM   #2
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Depending on model of A/C, the black rubber drain line typically runs between the outer and inner skin down the left (street) side of trailer. Starting point at top is usually at edge of plastic drain pan around base of A/C, but it may also be inside of 14" square foam "gasket" seal, and so can't be seen from outside... Ours drained from outside, since foam gasket itself was source of leaks inside trailer onto floor under unit. It leaked water onto floor when it rained... As painful as it sounds, you may have to remove sheet metal and plastic grills from inside and below to get at tubing...
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
Old 07-11-2006, 07:00 PM   #3
Alice Crane
The water from the AC goes into a drain pan. You cannot see the area where the water collects and then drains out.
If the water is drain, leave it alone, as you could disconnect the drain line from the pan.
Also, if you remove the interior AC shroud, you will see where the drain line connects to the drain pan.
Old 07-11-2006, 07:05 PM   #4
acrane's Avatar
1980 31' Excella II
Could not see
Andy we removed the shroud and couldn't see any drain line connection. We have 1980 Excella
Alice
Old 07-11-2006, 07:09 PM   #5
Alice
Alice.
You must remove the "interior shroud", the one that is "inside" the trailer.
You should see a black plastic tubing connection to the bottom of the pan. That tubing is on the road side of the 14 x 14 cutout.
I am assuming the AC that you have is the original Coleman.
You won't see anything from the top of the AC.
Old 07-12-2006, 10:37 AM   #6
acrane's Avatar
1980 31' Excella II
Is my face RED!
Well I just found the information section in the manual but it does not show location of drain. We are going "inside" as suggested to see if we can find the beginning.
Tks Alice
Old 07-12-2006, 11:00 AM   #7
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Alice, yours may look something like this. This is from a 1973 model, looking up from inside the camper.
http://www.airforums.com/forum...50-post10.html
www.nesa.org
Air No. 6427
Old 07-12-2006, 11:08 AM   #8
acrane's Avatar
1980 31' Excella II
Not sure if same
Jim/Susan
Doesn't look like ours but we may not have gone deep enough.
We took the inside shroud off and all we saw was a metal box with two large wires on the side. It is bolted in on both ends. Are we suppose to remove the bolts?
Alice
Old 07-12-2006, 11:31 AM   #9
Roadtoaster's Avatar
2015 30' Flying Cloud
Byhalia , Mississippi
Alice, although my unit is new, I have been in the inards of my ac to try and rectify a humidity problem. The bolts you describe are holding the bottom mounting portion of the unit, view it as the bottom half of a clamp. Remove the bolts and drop the bottom section. Make sure the power is off. Don't know what you will see but you must do this to get access.
Greg
Roadtoaster is offline   Reply With Quote
Old 07-12-2006, 11:34 AM   #10
Alice, I suspect yours is identical to ours. Once the inner plastic shroud is off, look up on the street side at the front, where the large metal tube of wires goes into the metal box (about 3 inches square) which houses the switch mecjhanisms. Put your hand above near where the wires enter the back of the box, and you can just see a small black rubber tube held on with a hose clamp. Good hunting. Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 07-12-2006, 12:08 PM   #11
Alice, re. the above posts, on mine there is no need to remove the large clamping bolts to drop the inner metal sheet. Just look above where the metal tube containing the wires goes into the back of the control box. I looked for this drain tube connection over a couple of years, and eventually traced it just by luck. Once you catch sight of it you'll wonder how you missed it. Mine is a Coleman Delta TX.
Nick.
Old 07-12-2006, 01:08 PM   #12
acrane's Avatar
1980 31' Excella II
MY Husband and AC
My husband may kill the a/c before we find the hose. He went outside, put me inside with shroud off and electicity off. He put water up the lower outside drain. It had no trouble coming in trailer. Put shroud & electricity back on, a little while later water running down ourside of trailer.
So, now that I have read latest post, when he gets back from store, we will try this again. After we do find the opening, what do we do, try running air through it? We tried that from the outside, 125 lbs. and could hear a little air. But seem still mostly clogged up.
Alice
Old 07-12-2006, 01:10 PM   #13
acrane's Avatar
1980 31' Excella II
I meant to say our a/c is a coleman
Alice
Old 07-12-2006, 01:59 PM   #14
Got gandkids?
If you are sure the round tube that runs from the tray under the coils is clear from top to bottom, then I would think either the tray is blocked or the coils are blocked and not allowing water to drain into the tray, then into the tube, then ouside the trailer.
www.nesa.org
Air No. 6427
low drain points Raptorrider2001 1999 Safari 19 11-13-2015 01:40 PM
AC location - 1966 Forrest 1965 - 1969 Globetrotter 0 04-17-2004 09:07 PM
Globetrotter 1963 - Kitchen Sink Drain Leak Under the Floor Uncle_Phil Plumbing - Systems & Fixtures 3 08-09-2002 06:59 PM
Check your aging A/C shroud Jim Clark Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-25-2002 10:30 PM
Air conditioner drain jcanavera Furnaces, Heaters, Fireplaces & Air Conditioning 3 07-10-2002 01:52 AM
