Old 07-12-2006, 02:12 PM   #15
acrane's Avatar
1980 31' Excella II
Stonewall , Mississippi
Jim would this be...........
Would this tray be inside or outside?
acrane is offline   Reply With Quote
Old 07-12-2006, 02:44 PM   #16
Alice, this thread describes the procedure to access the tray, clear out the area around the drain tube, and fit a new gasket:
http://www.airforums.com/forum...ck+roof+gasket
You will need to read the whole thread to get the idea, particularly the last post about cutting slots in the gasket. The tray is an Airstream part, which is sandwiched between the roof unit and the internal unit. It can only be accessed when the roof unit is removed or tilted on edge, after the internal unit has been removed.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 07-12-2006, 03:21 PM   #17
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Nick, that is a great explanation of how to track and repair leaks around the A/C unit. I've added it to my list of "greatest hits" threads!
www.nesa.org
Air No. 6427
Old 07-12-2006, 03:30 PM   #18
Thanks, Jim. A little appreciation goes a long way!
Nick.
low drain points Raptorrider2001 1999 Safari 19 11-13-2015 01:40 PM
AC location - 1966 Forrest 1965 - 1969 Globetrotter 0 04-17-2004 09:07 PM
Globetrotter 1963 - Kitchen Sink Drain Leak Under the Floor Uncle_Phil Plumbing - Systems & Fixtures 3 08-09-2002 06:59 PM
Check your aging A/C shroud Jim Clark Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-25-2002 10:30 PM
Air conditioner drain jcanavera Furnaces, Heaters, Fireplaces & Air Conditioning 3 07-10-2002 01:52 AM
