Old 07-20-2013, 07:56 PM   #1
1984 31' Limited
Dade City , Georgia
AC drain line
Can anyone tell me what the route of the ac drain line might be on a 1984 Excella 34' trailer? Or, if I need to replace it altogether, what size & type of tubing should I use and, how should it be run(for example: on which side of the trailer, behind the fridge, etc.) I will be installing a new Penguin with a new drip pan and need to know if this can be done. Thanks.
Bill C. is offline   Reply With Quote
Old 07-20-2013, 08:02 PM   #2
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
Mine is a '72 Tradewind....the drain line runs street side in the wall cavity just forward of the wheel well...and exits through a hole in the sub-floor and belly pan. I think it is 1/2 inch tubing.
arktos55343 is offline   Reply With Quote
Old 07-21-2013, 11:51 AM   #3
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Same on my '93, comes out just in front of the front, street side tire, in the curved wrap.
John
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 Past President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?..... Uncle John's Band
sandlapper is offline   Reply With Quote
Is there a drain for the AC? perryg114 Furnaces, Heaters, Fireplaces & Air Conditioning 19 12-12-2018 09:15 AM
How to disassemble a drain valve flyflinger Fresh Water Systems 2 09-25-2011 11:17 PM
How to drain? sarasafari Waste Systems, Tanks & Totes 1 09-17-2011 01:02 PM
Carrier Normal Profile - Add Drain Line vhariable Furnaces, Heaters, Fireplaces & Air Conditioning 7 05-01-2011 01:51 PM
