Old 07-17-2005, 10:48 AM   #29
thank you, overlander63.
I think any working AC will be a vast improvement over what I have now.
I wonder if the aluminum skin absorbs, or rather retains more heat than other type of skins. (But I like it anyway)
I'll keep updated on developments...
Justice - When you get what you deserve. Mercy - When you don't get what you deserve
Grace - When you get what you don't deserve
ipso_facto is offline   Reply With Quote
Old 07-17-2005, 02:48 PM   #30
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
I think adequacy is an objective thing when it comes to A/C sizing. I've been happy with the 12.5 K BTU Armstrong in the 31. Fortunately, it's still going strong. I put a Carrier 5 15 K in the 28, and it's got a BIG margin over the 12.5. Still, I'm happy with the thought that a 15 to 20 degree temp difference over outside is what I'm satisfied with, and with care, this Armstrong will still be running when the Carrier is disposed with.
(I also think that having awnings on three sides and a rock guard up front contributes a lot to cooling. My Argosy does not have any of those.)
Lamar
SafeHarbor is offline   Reply With Quote
Old 07-17-2005, 05:27 PM   #31
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Lamar
For whatever reason, probably better design, the Armstrong A/C seems to cool better at 12.5, than most other units do with 13.5, or even 15k.
Old 08-13-2011, 12:54 PM   #32
Antipode's Avatar
1975 Argosy 28
Spicewood , Texas
The lucky ones
Thiss is a great site! New here and my first post. I've been unable to find some of what i'm looking for but this may help.
I just reserected a 1975 Argosy 28 from an Aspen glade in Colorado and returned home to Texas after packing bearings and buying new tires, plugged it in to shore power to find the A/C blew air but not cold. Frige did not cool on Elec either. Water and LPG to be tackled later.
I asked an HVAC friend over and we pulled the "squirrel cage" apart (20+ poprivets, is that normal?) to find it still held factory charge of R-22. We CHANGED AWG in extention cords, went below to the thermostat switch and jumped it. There she blows, 50+ degree air. Did you check the thermostat? (the one with the temp lead coming out the back side). I have been fortunate with this salvage. After getting the roof back together and finding a new Ranco switch, I'll be onto the frige.
Originally Posted by ipso_facto View Post
desi arnaz wrote:
> coul be you just need a new a/c unit?
That's it.... I replaced the breaker, which was the problem, as it turns out and the AC does not cut off anymore.
However, I think the compressor is going out. It's just blowing air which isn't cold. I think this is the original, 20 year old unit, so I suppose it did good, considering there is only a 2 year warranty on these Colman units.
Any idea if the above is true, and if so, what's a good place to get a Colman AC unit? Is it possible to find a used one?
Work Camping, Reno is $4,100 and climbing.
Antipode is offline   Reply With Quote
zip-dee doo dah day nettepdx Awnings 17 10-21-2004 05:51 PM
The More I Polish...The Lower My Standards are Getting !! MileHigh Cleaning, Stripping & Polishing 49 06-08-2004 12:06 PM
Fridge Cuts out When I Start the Engine swebster General Motorhome Topics 7 05-19-2004 11:24 AM
Generator cuts off ALANSD Airstream Motorhome Forums 7 08-03-2003 08:36 AM
Yukon AC cuts out towing.... dscluchfc On The Road... 10 07-27-2002 11:01 AM
