Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 07-02-2008, 04:26 PM   #1
Profile:  1986 32' Excella
vledder , drenthe
AC cools a liitle but not cold
The original AC on my 86 exella cools not enough.
could it just be low on refridiant and can I fill with the bottle's with leakstop that there are for sale for cars ?
How importand is the type of coolant?
In a car you can just fill the sysatem with liqued propane and it works fine.
Remco
remcolent is offline   Reply With Quote
Old 07-02-2008, 04:30 PM   #2
Moderator Emeritus
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
What brand is it? If it's a Coleman, you may have to replace it. There are no servicing valves on RV air conditioners, as a rule. You can install piercing valves, but those leak most of the time. Cost to have this done can approach pricing on a new unit. But if your an HVAC guy, have all the equipment and R22, you may be able to save some bucks.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 07-02-2008, 04:53 PM   #3
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
First thing I would check is the coils to be sure they are clean. If not clean them with coil cleaner and get a good air flow.
It is unlikely you have a low charge. Low charge would result in ice on the coils and the air flow would stop.
If you can remove the cover and while the AC has been running for at least 5 min. feel the suction line, the large one. It should be cold, ideally it should have water on it if the humidity is high. If it is dry and warm the compressor may have a valve leak pushing warm gas back into the suction line. This would cause poor cooling.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 07-02-2008, 05:52 PM   #4
vledder , drenthe
instaling servicing valve would be no problem.
I will do the test on the compressor.
I'm familiar with the automotiv AC systems but this is unknown to me.
If the compressor is gone can I replace it with compressor that I find in the large restourant walk in fridges?
If I look at the power consumption they are about the same
A compressor from a normal refridgirator will be way to small.
remco
Old 07-03-2008, 07:13 PM   #5
vledder , drenthe
I looked @ ebay for a new AC
A coleman 15000 btu for around 550 usd.
For a 5500 btu we have to pay around 2400 usd here in holland.
I think I order one is the US even with shipping and tax it will be only about half of what we have to pay here.
Remco
**How Cold is it?** Silvertwinky Off Topic Forum 728 02-05-2009 07:36 AM
Refrigerator not getting cold billberk Refrigerators 30 05-14-2008 10:40 PM
Hello from cold Wisconsin BigD Member Introductions 3 04-07-2007 09:15 PM
Refrigerator too cold wingfoot Refrigerators 1 09-08-2003 10:13 PM
