Old 04-09-2015, 01:52 PM   #21
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Or-
http://forums.mikeholt.com/showthread.php?t=148102
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 04-09-2015, 01:54 PM   #22
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
It sounds like maybe you can switch the wire on the start capacitor to reverse direction.
Old 04-24-2015, 04:10 PM   #23
etobicoke , Ontario
Eagleuh1, the guy who replaced your connections earlier didn’t do a very professional job at all, the engineering conventions haven’t been taken care of either. Being an engineer I firmly believe that such repair jobs are our worst nightmare. Please note that you’ll have to replace the capacitors and make sure they aren’t polar as mentioned above. Although you can tape the wires but using a paper tape would be best since it doesn’t affect the capacitors in the long run as much.
caliskan is offline   Reply With Quote
Correct Capacitors for Armstrong A/C fan & compressor Danny Bell Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-03-2014 12:10 AM
univolt capacitors mpc Batteries, Univolts, Converters & Inverters 2 09-15-2007 06:55 PM
Capacitors on Older Electric Brakes Navigator Brakes & Brake Controllers 6 11-25-2003 01:39 AM
