01-22-2010, 12:53 PM
64GlobeTrotter68Overlande
1964 19' Globetrotter
1969 27' Overlander
Snohomish
AC Can You Get An Efficient System?
The AC I have makes a lot of noise and little cold and sucks the power. Is there modern more efficient units out there? Bet there are no DC units for boondoggling...
Wife like's AC, I hate it
01-22-2010, 01:12 PM
Corona
What exact brand AC do you now have.
Forget the 12 volt DC issue. No such animal.
Most new AC units are efficient.
01-22-2010, 02:00 PM
1969 27' Overlander
Snohomish
Andy,
It's a Duo-Therm by Domestic. Figured there would not be a 12V version but thought I'd ask.
01-22-2010, 02:31 PM
Corona
Andy,
The original AC for a 1964 was mad by Armstrong and it was model # TAC-110.
Obviously it's been replaced with a Duotherm, but you also say Domestic, which is really Dometic.
The question becomes which model so that you could know how old it is.
Please post the model number and I will try to help you determine it's age.
01-22-2010, 02:50 PM
1969 23' Safari
New Orleans
, Louisiana
I've always wondered if anyone made a 8K btu type unit as the 13.5 and 15K units are Way too big for the smaller trailers. Andy? Our 15 blows like a freezing hurricane!
01-22-2010, 03:05 PM
Wise Elder
2010 30' Classic
South of the river
I believe the Coleman "Polar Cub" is an 8000 BTU unit.
01-22-2010, 03:08 PM
Corona
Rick.
There are 4 choices, for roof AC's.
7,100, 11,000, 13,500 and 15,000 BTU.
For your 23 footer, plus being in the southern US, I would feel that the 13,500 should do the trick for you.
But, when you get those nasty hot spells that sometimes last for weeks, a 15,000 does the trick.
Also, since you have a nice looking trailer, an Airstream, putting a 7,100 BTU AC on it's roof, will make it look horrible.
Keeping the thermostat up a little higher should help your issue with the AC.
When it comes to AC's, a little more cooling is always better that a little "not enough".
01-22-2010, 03:11 PM
I installed a 8k btu window AC in my Safari. Craigslist=$50.00 came with remote control even. New in the box cost about $200 to $250 compared to $1200+ for that low-profile coleman roof-mount job. It gets my Safari down to 65degrees on a 90+ degree day. It can easily be run with a 2k Honda generator, along with a few other things. Mine is mounted in the former furnace location and slides out for use so it can drip right onto the ground. I have since installed the old furnace shroud to the sliding tray so you can't tell it's there.
Rich the Viking
01-22-2010, 03:20 PM
1967 24' Tradewind
Greenville
, South Carolina
Rich,
That's a pretty cool and economical idea. I may consider that. So, is there a tight seal around the air conditioner? If so, how is it sealed?
Thanks, Michael
01-22-2010, 03:22 PM
Corona
Part of choosing an AC, for an Airstream, is does it have a drain pan available for it, so the water does not run down the side of the trailer.
The Carrier, is the only unit that did not require a drain pan.
01-22-2010, 03:46 PM
The aluminum plate that the shroud mounts onto was riveted to the outer skin, so I drilled out the rivets and installed a gasket onto the back of the plate. I will eventually replace it with a riveted on gasket. When opened it has a foam gasket that will seal to the inside wall of the Safari. It's not as critical as the outer gasket, as it won't be used when it's raining anyway, Unless it's a really, really hot rain!
Rich the Viking
01-22-2010, 05:25 PM
1965 28' Ambassador
Irving
Cool Rich!
01-22-2010, 06:26 PM
tallahassee
Rich the Viking
Rich,
Have you detailed this installation in a thread?
Nice,
Carol
01-22-2010, 06:47 PM
Hi Carol,
I have not done that yet, but I find myself answering a lot of questions about it so I better get to it, huh? The installation is not complete yet, but the issues of mounting it and sliding it out are done. I will start a thread on it, and I appreciate the comment.
Rich the Viking
Originally Posted by tallytwo1994
Rich,
Nice,
Carol
01-22-2010, 06:59 PM
Port Hadlock
I like, too, Rich. Get a thread going or we'll totally hijack this one.
01-23-2010, 06:54 AM
1969 27' Overlander
Snohomish
Rich, go ahead hi-jack this thread, we are all interested. I can then get rid of the ugly top unit, the anti Air-Streaming drag unit
01-23-2010, 07:09 AM
1967 24' Tradewind
Greenville
, South Carolina
Rich,
You have certainly generated a ton of interest in your AC solution! can't wait to see more pics.
01-23-2010, 08:20 AM
Naysayer
1968 24' Tradewind
Russellville
, earth
I hate to be Mr downer, but, if house units were an optimal solution, wouldnt manufactures be installing them at the factory? Will a house unit hold up to the rigors of road travel?
01-23-2010, 09:23 AM
1969 23' Safari
New Orleans
, Louisiana
Rich the Viking
Not only is that a cool install, but it puts you in very esteemed company as I believe the 'legendary' Fred Colwell has a similar installation. Sure keeps the profile of your trailer looking sweetly vintage. Nice work!
01-23-2010, 09:25 AM
Corona
Rich the Viking
How do you keep the rain water out?
