Old 04-22-2016, 06:31 AM   #1
Member Slide Out Society
2004 28' Safari S/O
Zavalla , Texas Airstream Harbor
A Little Help from my friends!
Hot Water heater woes..1994 Airstream Atwood Water Heater..replaced Ignitor board…checked thermostats and power from the inside switch all good. The silly thing will still not come on or work. Question: When the switch to the Hot Water heater is turned on there is no red light…does the light in some way play a part in the electric equation?…
What else should I check?
Rockwell is offline   Reply With Quote
Old 04-22-2016, 08:19 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
the most common failure of a hot water heater is the thermistors. There are 2 small, dime size buttons, attached to the face of the heater. Often behind a cardboard cover. They control the on/off function of the heater.
If the heater is cold both should be closed. To test remove the connecting wires on either side of the pair and test for continuity across them. If the test shows an open one has failed and you should replace them. They are about $20.00.
You can test the heater by replacing them with a jumper wire. Jumper them and try to light the heater.
Do not use the jumper to get the water to a usable temperature as you may have an explosion on your hands.
2004 Excursion 4x4
Old 04-22-2016, 09:13 AM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
The light is a "fail" light. If the heater fails to ignite the light comes on. If the heater does not ignite after a short time the light comes on.
Old 04-22-2016, 09:13 AM   #4
2004 28' Safari S/O
I've check the continuity on the thermostats…it shows to be closed…the heater is cold…My manual shows an EGO switch on the back of the hot water heater with a red reset button…generally a safety switch for overheating…thoughts of that button needing reset?…quiet a chore to get to..
Old 04-22-2016, 09:15 AM   #5
2004 28' Safari S/O
Bill M…no red light at all…worked before however..
Old 04-22-2016, 10:18 AM   #6
HowieE's Avatar
Images: 12
If the high side thermistor was fused closed and the heater when off on high limit, the EGO switch, I would reset the switch. If the heater lights after that i would consider changing out the thermostors.
The low thermostor closes on temperature drop, thus allowing the heater to light. The high thermosotor opens on temperature rise, thus turning the heater off. The failure mode for the high side is not that easy to check.
2004 Excursion 4x4
Old 04-22-2016, 11:47 AM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Have you checked to see that there is 12 volts at the water heater. Maybe you have a blown fuse.
TG Twinkie is online now   Reply With Quote
Old 04-22-2016, 02:05 PM   #8
HowieE's Avatar
Images: 12
it may sound strange but make sure you have gas at the heater. Crack the gas line at the heater and leave it cracked till you smell gas.
While the heater can usually purge any air in the line ,from changing tanks, it won't hurt to make sure.
When trouble shooting you have to cover all bases.
2004 Excursion 4x4
« 12 volt | Top | New AC »
Needed ~ a little help from Airstream Friends! CaddyGrn Off Topic Forum 11 09-08-2009 11:35 PM
New Owners! New Friends! jommie Member Introductions 5 01-13-2006 01:41 PM
Looking for friends... summerkid Our Community 16 07-03-2004 09:56 PM
Just wanting to say to my new friends... KY Girl Our Community 13 12-26-2002 01:22 PM
Friends attending mareinmn Other Rallies & Events 1 09-18-2002 08:05 AM
