Old 07-30-2005, 07:34 PM   #1
2002 30' Classic S/O
Banning , California
a/c won't start
the a/c on my 01, 30 classic/so won't start. I do not have an owners manual , so i'm stuck, and it's hot in here! I need to know the location of the fuse/breaker box or anything else that will help me solve the problem. The a/c unit is a Penguin with a comfort control unit for the programming. Can anyone point me in the right area to trouble shoot my problem?
Chipster is offline   Reply With Quote
Old 07-30-2005, 09:51 PM   #2
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
The fuse box should be in the roadside rear overhead cabinet. Not at all unusual to pop a breaker in hot weather, especially if AC voltage is a bit low and either the microwave or the electric rod in the water heater happens to be on when the A/C starts up.
You might need to reset the Comfort Control. Hold down the top and bottom buttons while you turn the CC on. Keep holding the buttons down for a few seconds and then release them. This action resynchronizes the A/C and the CC.
There is a substantial delay between selecting A/C on the CC and the A/C actually starting up. This delay is to protect the compressor, but it can really get frustrating when you first hook up and want to get the trailer cooled down in a hurry.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Old 07-30-2005, 10:32 PM   #3
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Older units have a switch which lets you run the microwave OR the AC but not both.
I don't know if yours has one too
guy99 is offline   Reply With Quote
Old 07-31-2005, 04:26 AM   #4
JPAIRSTREAM's Avatar
1972 31' Sovereign
, Ohio
Images: 47
Breaker boc should be over the bed.. If you have no power to the Comfort control there is also a fuse under the outside shroud
JP
JPAIRSTREAM is offline   Reply With Quote
Old 08-01-2005, 09:57 AM   #5
Thanks for the information on the a/c. I found the breaker & fixed the problem.
A/C replacement? VWMARTINEZ Furnaces, Heaters, Fireplaces & Air Conditioning 6 03-09-2007 02:14 AM
Help!! Engine Won't Start!! eraffety Mechanics Corner - Engines, Transmission & More... 41 07-05-2006 07:01 PM
1971 Armstrog A/C uwe Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-06-2002 05:08 PM
Missing piece for Armstrong A/C? 74Tradewind Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-10-2002 04:16 PM
Mediocre A/C Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-07-2002 07:52 PM
