Old 09-14-2009, 10:27 PM   #15
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
Some power converters, like mine,[charge wizard] have fuses built in, separate from the fuse box.
You can check your charger by disconecting the battery and see if you have any lights in the trailer and/or voltage on the battery cables. Be careful not to short out the cables,if the charger is working,they will be live.
bibbs is online now   Reply With Quote
Old 09-15-2009, 06:47 AM   #16
Grumpycamper's Avatar
2005 16' International CCD
Wimberley , Texas
Just a thought, is there a possibility of reverse polartity in your 30 amp service?
Grumpycamper is offline   Reply With Quote
Old 09-15-2009, 07:29 AM   #17
HeadnOut's Avatar
Ruther Glen , Virginia
Had a friend just go thru something very similar...his converter was shot. That would be me guess to start with.
Keep your nose to the wind and your eyes on the horizen.
HeadnOut is offline   Reply With Quote
Old 09-17-2009, 03:52 PM   #18
sherrylynne's Avatar
2007 23' International CCD
vero beach , Florida
Update: Converter was shot. I did a search in the forums under Parallax and came up with a few different threads. One of which had the website bestconverter.com on it. I called Randy and shot a couple questions at him. He told me that the converter was bad and I ordered a new unit. I will update after I install the new unit. It is a Progressive 4655. Thanks for all the help and suggestions!!
sherrylynne is offline   Reply With Quote
Old 09-17-2009, 06:16 PM   #19
HeadnOut's Avatar
Glad to hear you found issue was the converter. They can act very funny when going bad and lead you in many different directions as to what could be wrong.
let us know how the swap out goes.
Old 10-15-2009, 06:20 PM   #20
Got the converter the other day. re wired everything. had to use a different punch out to re route the battery leads but everything went well. Huge ants nest back there. we had an ant problem a while ago but got rid of them. They used all kinds of metal shavings and insulation. Installation went well. Randy over at bestconverter.com is very helpful and patient. I had a few questions... Thanks for all the help guys! Now if I could do something about the filiform corrosion...
elec jack won't work, manual override won't budge? Randjg1 Jacks, Stabilizers, Lifting and Leveling 17 07-04-2009 10:19 AM
furnace wont start matthew NYC Furnaces, Heaters, Fireplaces & Air Conditioning 5 02-15-2009 06:11 PM
You guys wont believe this... Mrcrowley Nu-Tone Appliances & Central Vac System 7 08-18-2008 02:08 PM
Oh no it wont move!! Angel73 Fresh Water Systems 9 03-17-2007 10:56 AM
