Old 03-25-2006, 04:57 PM   #1
hantri's Avatar
1973 31' Sovereign
1963 19' Globetrotter
Graham , Texas
A/C will not do anything
Our first time to try a/c in 73 soverign. NOTHING. We are hooked up with
an extension cord (14) from the house. Unit is a Penquin. Any suggestions will be gratfully excepted.
Jill
hantri is offline   Reply With Quote
Old 03-25-2006, 06:02 PM   #2
Jill, if your trailer has a microwave oven, the trailer may be wired so that a hidden switch enables you to use either the microwave, or the A/C, but not both at the same time. The 30 amp supply is not sufficient to run both simultaneously. In our trailer, the switch is in the locker above the stove, and it is labelled for microwave in one direction, and A/C in the other switch direction.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 03-25-2006, 09:04 PM   #3
GStephens
GStephens's Avatar
1982 31' Limited
1953 25' Cruiser
Hamilton , Texas
I second Nick's suggestion. First, look in or below the overhead cabinets above the sink and stove. Often there is a switch that looks just like a toggle light switch in your home. One direction allows operation of the microwave while the other allows you to operate the air conditioner.
GStephens
GStephens is offline   Reply With Quote
Old 03-25-2006, 09:20 PM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
'73 = Microwave?
I would think it would be an after-market modification, if it had one....right?
Not likely it was built-in with a switch and all...in '73.
Shari
Old 03-25-2006, 10:21 PM   #5
fastrob's Avatar
1976 25' Tradewind
. , AZ to Maine
Thermostat
On mine there are two thermostats. One up front for the heater. The second is for the a/c in the middle near the beds. They both have switches. The front thermostat controls power to the a/c and heater. I still get confused.
Circuit breakers are in the back by the toilet in the closet.
A light power supply line will cause the unit to pop circuit breakers in the supply and trailer.
R
fastrob is offline   Reply With Quote
Old 03-26-2006, 02:49 AM   #6
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
You definitely need a 10 gage extension cord. You should also have a voltmeter to see that the power is actually reaching the AC. Without the meter it will be difficult to trouble shoot your problem.
frig and a/c suggestions Neenm General Appliance Topics 6 04-08-2007 07:42 PM
A/C replacement? VWMARTINEZ Furnaces, Heaters, Fireplaces & Air Conditioning 6 03-09-2007 02:14 AM
1971 Armstrog A/C uwe Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-06-2002 05:08 PM
Check your aging A/C shroud Jim Clark Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-25-2002 10:30 PM
Mediocre A/C Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-07-2002 07:52 PM
