I have a 13,500 Dometic A/C unit and when running it seems that the compressor noise is picked up by one of the room frame members which makes the noise very annoying as it is propagated throughout the unit.
I wonder if there is an issue with how the A/C unit was installed. This is not the original A/C unit in my 1994 34 footer.
It is a function of basically hard mounts to a metal frame and being an average of 5 feet from an unsound insulated unit. In a house the AC is usually placed in an unused part of the house behind closed doors.
MICHAEL
2wks ago turned my AC on . you could have churned butter in the trailer. Pulled outside shruod removed dirt dauber nest and instantly good and smooth. Check both sides of fan.
It's an excellent idea, but would need regular cleaning to keep dirt buildup off it.
Sent from my pocket Internet using Airstream Forums
