Old 06-15-2016, 02:25 PM   #1
1994 34' Excella
West Liberty , Kentucky
A/C Vibration Noise
I have a 13,500 Dometic A/C unit and when running it seems that the compressor noise is picked up by one of the room frame members which makes the noise very annoying as it is propagated throughout the unit.
I wonder if there is an issue with how the A/C unit was installed. This is not the original A/C unit in my 1994 34 footer.
Any suggestions or help will be much appreciated.
MR AIRSTREAM is offline   Reply With Quote
Old 06-15-2016, 03:59 PM   #2
"Cloudsplitter"
Thumbs up Welcome Aboard....
New unit?....no noise in the past?
Take the AC shroud off and check the 'mouse wheel' fan for a mud-dauber nest....ask me how I know.
Old 06-15-2016, 04:11 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
It is a function of basically hard mounts to a metal frame and being an average of 5 feet from an unsound insulated unit. In a house the AC is usually placed in an unused part of the house behind closed doors.
MICHAEL
Old 06-16-2016, 03:36 PM   #4
1990 32' Excella
jonesboro , Arkansas
2wks ago turned my AC on . you could have churned butter in the trailer. Pulled outside shruod removed dirt dauber nest and instantly good and smooth. Check both sides of fan.
joel is offline   Reply With Quote
Old 07-24-2016, 07:06 PM   #5
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
So I'm there, getting ready to pull the shroud off to clean off another nest.
Has anyone put screen material on the inside of the shroud to keep the mud daubers from building nests? Would it cut down on the airflow to much?
Silverflames is offline   Reply With Quote
Old 07-24-2016, 07:29 PM   #6
2007 22' International CCD
A/C Vibration Noise
It's an excellent idea, but would need regular cleaning to keep dirt buildup off it.
Old 07-24-2016, 09:16 PM   #7
1969 29' Ambassador
Good point.
Old 07-26-2016, 07:10 PM   #8
1969 29' Ambassador
Opted not to put the screen in, I would never clean it.
I did paint the cover silver!
Motor noise vs fan noise vs overdrive question SebasSF Mechanics Corner - Engines, Transmission & More... 25 12-15-2013 11:18 AM
Tranny Tailshaft Vibration? swebster Mechanics Corner - Engines, Transmission & More... 31 02-22-2006 06:33 PM
Intermittent Chassis Vibration Chaplain Kent Mechanics Corner - Engines, Transmission & More... 29 10-29-2005 09:49 PM
Furnace Vibration and Noise flyfisherman Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-16-2005 07:37 PM
1997 "B" generator vibration & noise TuckerT Sprinter and B-van Forum 0 10-06-2004 06:42 PM
