Old 07-10-2014, 01:53 PM   #1
Freedomrider's Avatar
2013 30' Classic
Lakeland , Florida
A/C vent not blowing Air
Hi All,
Help please.
Just noticed that both my A/C units does not blow air out of the right side vent only (vent on the street side). Vent on the left side and both ends blow air forcefully all the time on both units, when open. If I shut off all vents except the right vent, air will come out forcefully on the right side.
If air comes out all of the vents forcefully when open, why would it not come out of the right vent?
Took the unit to Colonial, a couple of weeks back, they stated "Duct work not connected properly in both A/C units. Connected duct coming from fan." I took their word for it and did not check it before I left. All I can tell you, I still have the same problem.
Now thinking about it, how does these units have duct work?
We are now up in Mass., with another appointment scheduled to address this issue.
Any help would be appreciated to help me understand and address this issue.
Thanks.
Freedom Rider and Roadrunner
2013, 31 'Classic
2012, 2500 Ram Longhorn, Air Safe, Reese Hitch
Freedomrider is offline   Reply With Quote
Old 07-10-2014, 03:45 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
I suspect there is nothing wrong. Air flow off a fan will have high and low areas of flow depending on the internal configuration of the unit. If you want to increase the flow in that one direction you my want to choke down the other vent a little. This is known in heating and air conditioning as balancing.
2004 Excursion 4x4
HowieE is online now   Reply With Quote
Old 07-12-2014, 02:40 PM   #3
2013 30' Classic
Lakeland , Florida
Thanks HowieE,
Your info is much appreciated. Education means a lot when you do not have any. My A/C works great. I am just trying to cover all of my bases, now that the warranty will be running out in a couple of months.
Thanks again for your thoughtfulness.
2013, 31 'Classic
Old 07-12-2014, 05:40 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by Freedomrider View Post
Hi All,
Help please.
Thanks.
There is no 'duct work' per se in these units, but they do employ a square shaped air plenum that directs the exhaust air coming from the evaporator fan opening of the unit to the plastic air distribution box where your adjustable vents are located. This is what Colonial was probably referring to.
If you still have this problem, I would take down the plastic air box and look inside it to be sure that the plenum material is properly fastened all around it's housing.
Old 07-14-2014, 06:01 AM   #5
2013 30' Classic
Lakeland , Florida
Thanks Lewster,
This is good to know how the system really works. I am scheduled to take my unit to a Dealership in New England, of course, who did not seem too concerned this is an issue. However, we are to discuss it again when we bring it in. This info will definitely help to discuss it intelligently. If not a positive response, there will be other places to take it before the warranty expires. Thanks again.
2013, 31 'Classic
Oh oh, heat pump only blowing cold air almcate Furnaces, Heaters, Fireplaces & Air Conditioning 11 12-17-2013 03:17 PM
furnace blowing cold air canine camp Furnaces, Heaters, Fireplaces & Air Conditioning 55 07-26-2013 11:14 PM
Air Conditioner Only Blowing at 50% Fly at Night Furnaces, Heaters, Fireplaces & Air Conditioning 11 08-04-2012 10:55 PM
Heat Pump/Air Condition Blowing Hot Air Safari-Rick Furnaces, Heaters, Fireplaces & Air Conditioning 1 04-24-2012 08:30 PM
Heat Pump blowing cool air? craftsman Furnaces, Heaters, Fireplaces & Air Conditioning 11 04-08-2008 06:01 PM
