Old 06-09-2016, 12:18 PM   #1
1972 27' Overlander
Mathiston , Mississippi
A/C Unit
Need a new rooftop A/C for a 1972 27' International Land Yacht. Can anyone give recommendation?
marciamills is offline   Reply With Quote
Old 06-09-2016, 12:20 PM   #2
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Dometic Penguin II 15000 btu.
very low profile, white or black shroud.
Looks perfect on any Airstream
Old 06-09-2016, 01:20 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Yeah looks perfect, reliable but noisy inside. A higher profile unit will be quieter.
Old 06-10-2016, 10:05 AM   #4
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Recommendation: Fix the existing Armstrong unit instead.
Old 06-29-2016, 08:06 AM   #5
1975 31' Romany
Kansas City , Missouri
Who can fix them? My compressor bearing is going out and when it heats up the ac shuts down and will restart after it cools down
kosullivan is offline   Reply With Quote
Old 06-29-2016, 10:09 AM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Are you sure it isn't the condensor fan motor?
Old 06-29-2016, 11:26 AM   #7
drboyd's Avatar
1978 25' Tradewind
As Overlander63 noted correctly, it's more likely to be the fan motor. The compressor bearings are sealed in an oily bath, and it's very unlikely that they would overheat, and even less likely that you would be able to detect it if they did.
The answer to "Who can fix them?" is "you." It's pretty likely that multiple {like 20+) drops of oil in each bearing port will do what you want.
The hard part willl be getting on the roof; there's a zillion threads on how to do that safely, so read up.
Remove the shroud by removing the four rusty screws on top and lifting straight up. You'll see the fan motor, and above each end where the spinning shaft comes out, you'll see a little plug thingy - like 1/16" diameter - that can be removed with a pair of pliers. Fill the resulting holes with just regular old shop oil, like 3in1 or 30 wt motor oil. Put the plugs back in, put the shroud back on, climb down safely, and pat yourself on the back.
In the unlikely event that that doesn't work, you'll have to replace the fan motor. But I'm betting the oil works.
Here's a generic picture of a fan motor showing the oil ports with the plugs removed:
http://www.hearth.com/talk/data/atta...327187c8b0.jpg
Old 06-29-2016, 03:25 PM   #8
drboyd's Avatar
1978 25' Tradewind
Oops! Correction! You'll have to remove a couple sheet metal panels to get to the fan motor. They'll be fastened with either Phillips head sheet metal screws or hex head sheet metal screws. It's just like taking apart a ball point pen, just a few feet in the air.
Old 06-30-2016, 09:44 AM   #9
1975 31' Romany
thanks for the info, I will try oiling it to see if that solves the problem
Pensacola Unit vs. Big Bend Tallahasse Unit gypsymoth WBCCI Forum 23 04-07-2013 11:19 AM
shopping for a unit to join at unit rallies GoNomad WBCCI Rallies & Events 35 11-30-2006 03:01 PM
Removing the Armstrong AC unit FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 11 08-02-2002 11:10 AM
Need info on A/C unit on a 1975 26 ft Argosy ... Hayseed Argosy Motorhomes 0 06-27-2002 08:19 AM
Washington Unit LKappenman Link Archive 0 05-22-2002 07:38 AM
