just guessing
hmm, interesting; one of the trouble spots on an rv is not having robust 120VAC to start up the airconditioning. A low voltage can cause slow startup and actually do damage to the air conditioner. so, perhaps the PO put in a small step up transformer to increase the AC by say, 10%? just a guess; ie: nominal 120VAC in, nominal 132VAC out; if the trailer is getting 108VAC, then it would increase it to 118VAC. What wires are connected, and how they are connected will tell ya what the thing is doing. If it is part of the air conditioning circuit, then it'll be in series with the Air conditioning wiring. If it does something else, there will be more than just the wires to the airconditioning.
