Old 03-27-2012, 10:48 AM   #1
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
A/C thermostat not coming on
New Dometic A/C with the Climate Control panel. Worked fine last Summer. Tried to turn it on for the first time this year and nothing. Would it be the thermostat or the actual A/C? I wonder that because there's just a phone cable connection. Is that a power supply? Local Airstream shop installed this, so I may just take it back to them. Should still be under warranty. But if it's one of those "oh, you just need to flip this switch" kind of things, then I'd rather save the trip...
adwriter73 is offline   Reply With Quote
Old 03-27-2012, 12:13 PM   #2
Crusty's Avatar
1992 34' Excella
The CCC gets it's 12V power from the main unit (needed to operate). Make sure that's there, check for popped 12V breakers. Also, don't forget about the semi-hidden on/off switch at the bottom right corner.
The cable looks like a phone cable but it's not. The connector is reversed at one end compared to a phone cable.
You can perform a master reset by switching the CCC off, then hold in the top and bottom buttons while you switch the CCC to on, then release them.
FWIW, I really like my 15K heat pump over the 13.5k ac that it replaced.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 03-27-2012, 01:10 PM   #3
richinny's Avatar
2011 34' Classic
how many buttons are on the CCC?
Ricky
Old 03-29-2012, 03:50 PM   #4
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
I remember seeing something about resetting. Going to try that. I didn't see any busted 12V fuses. The A/C power line is tapped into another line. If the reset doesn't work, then I'll check that power line. The semi-hidden switch you mention...is that the little nob that has a small guard on it? What is that? And which is the on position?
Old 03-29-2012, 04:01 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
The nob with the guard is a temperature sensor. The on-off switch is on the bottom of the thermostat.
Old 03-30-2012, 09:25 AM   #6
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
Oh ok. I thought you were referring to a secondary on/off switch. Thanks!
Old 03-30-2012, 10:41 AM   #7
Crusty's Avatar
1992 34' Excella
Is the CCC display completely blank or is something displayed on it? If blank then you're not getting 12V to it from the ac unit, which is transmitted via the "phone" cable. Is the circuit breaker for the ac unit flipped off? What position is the on/off switch in (under the bottom right corner of the CCC)?
Crusty
Lake Travis, TX
"Rancho Deluxe"
Old 03-30-2012, 01:19 PM   #8
Wise Elder
Jammer's Avatar
2010 30' Classic
The CCC is to modern Airstreams what rear-end separation is to 1970s ones. Just saying.
Old 03-30-2012, 01:46 PM   #9
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
It's completely blank. I've flipped all breakers to make sure they are not tripped. Checked the 12v fuse panel and all fuses are fine. Flipped the on/off switch a few times. Nothing. Is there another fuse in the A/C unit itself? Why would I suddenly not have power?
Old 03-30-2012, 01:56 PM   #10
Crusty's Avatar
1992 34' Excella
I think there's a fuse on the relay board inside the main unit. Unplug and replug the "phone" cable at both ends (switch off the power first). If that doesn't fix it then it's time to take it in.
Crusty
Lake Travis, TX
"Rancho Deluxe"
Old 05-01-2012, 12:17 PM   #11
adwriter73's Avatar
1978 31' Sovereign
Dallas , Texas
UPDATE: It appears that the wire the CCC connected to lost power. This is the second wire I tapped into that suddenly lost power. I checked all fuses with a volt meter and all are fine. I don't know what these wire went to as everything in the trailer appears to be working. Now, I don't know what else I can connect to. I tried three other nearby wires and they are lights and fans (only seem to deliver power with the switches are "on"). Thoughts???
TX Veteran Designation on Drivers License Bluto Off Topic Forum 43 06-27-2012 12:31 AM
New refrig-Not real cold Rich of SCal Refrigerators 18 06-03-2012 08:31 PM
help! final questions before we pull the trigger on a 25' Eddie Bauer bc_seattle Member Introductions 31 05-10-2012 09:08 PM
Lost pc (#2221) on Reese trunnion bar Denbear Towing, Tow Vehicles & Hitches 1 03-26-2012 08:30 PM
1995 Airstream 190 camper on Ford Econoline Club Wagon van eBay Watch Airstreams on eBay 0 03-26-2012 05:50 PM
