Old 10-07-2005, 05:37 AM   #1
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
A/C Thermostat
Does my 2005 19' Bambi Have an A/C Thermostat where it does not have to run all day and night or is that what it is supposed to do.
Would putting one in be ok or is that a bad thing?
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Old 10-07-2005, 05:51 AM   #2
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
What type AC
The Dometic Penguins come with thermostat, at least the ones I have seen.
Adding a T-Stat is not a bad thing. I would be willing to bet that there may be an optional interface within your AC that is intended for T-Stat hook up.
If you AC uses twelve volts for controls, it is even more simple to do.
smily is offline   Reply With Quote
Old 10-07-2005, 05:57 AM   #3
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
Devo,
Which AC did you get? Mine came with the LS upgrade and has a thermostat on the wall over the bathroom sink that operates the AC, heat pump, and gas furnace. The AC unit has three fan settings: auto, low, and high. If left on auto, the AC cycles on and off and can be kind of noisy, making it necessary to adjust the sound levels of the television, DVD/CD player, or radio. So lately I just set the desired temperature and set the fan on low. That way, the compressor cycles on and off at will, but at least the fan noise is at a constant level.
SilverRanger is offline   Reply With Quote
Old 10-07-2005, 06:36 AM   #4
dtbw's Avatar
1999 34' Limited
2002 19' Bambi
Allen , Texas
Upgrading to Dometic Digital Comfort Control
Devoman,
Your Bambi , unless is was an LS model, came with an 11,000BTU Penguin. This unit is has manual controls located on the AC interior shell. With those controls there is NO way to have the fan cycle with the compressor. These units CAN be upgraded to have the Dometic Digital Comfort Control Center (CCC) thermostat. This thermostat controls the AC, the heatstrip if installed, and the furnace. It allows you to set a constant fan speed or have the thermostat select a speed based on the delta between the set temp and the actual temp. In this mode it then turns off the fan as well as the compressor once the set temp is reached.
Fortunately A/S prewires all safari and bambi models to use the Dometic CCC. To convert the AC, an electronic module has to be added to the AC unit itself which replaces the manual controls, a new interior air distibution plenum (ie the plastic part where the air exits) is installed and the CCC is installed replacing the original wall thermostat used presently for only the furnace. The wiring to the original thermostat has to be connected to the prewire leads located near the existing thermostat which are in turn connected to the electronic module in the AC. A 4wire phone-wire type cable has to have connectors installed and that cable connects the CCC upto the electronics board installed as part of the upgrade in the AC unit. 12V is also required for the system to work, so that must be connected into the AC and the battery system, again, A/S prewires, but does not connect those wires.
All in all, the upgrade comes in a bit under $400 for parts and labor. We have done a number of these upgrades here at our dealership and while straightforward it is not a typical DIY project as you must know what you are doing and what wires go where. Dometics instructions are vague and aimed at trained technicians.
David Tidmore
WBCCI #7548
GM Roger Williams Airstream
Weatherford, TX
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
Past President Heart of Texas Camping Unit
WBCCI # 7548
dtbw is offline   Reply With Quote
Old 10-07-2005, 09:59 AM   #5
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
David,
That was great information you gave Devoman. And based on what I have read on this forum, I would bet that Airstream pre-wires for all possible upgrades. The Bambi was already on the lot, and during the negotiations, I told the salesman that I would probably have not ordered the A/V and LS upgrades, so he knocked off the price of all extras. In reality, I am really enjoying all those bells and whistles. The $400 tag on the AC upgrade makes me especially glad I got the LS package. The 13,500 BTU unit is probably more than the 19 footer really needs, but it cools the trailer off in just a few minutes on the hottest of days.
Old 10-07-2005, 12:23 PM   #6
Devoman's Avatar
Upgrade
Man...That is great info to know.Thank You.I think this is a good upgrade to get.
Old 06-01-2014, 09:18 PM   #7
2013 22' FB Sport
Wichita , Kansas
Is this a common upgrade for all dealers? Will my 22' sport be prewired for the t-stat?
Sent from my GT-N7100 using Airstream Forums mobile app
tallen5 is offline   Reply With Quote
Old 06-01-2014, 11:42 PM   #8
lewster's Avatar
Naples, FL , Hood River, OR
Remember that this thread is 9 years old. I'm not certain that the Sport models are pre-wired for the Comfort Control systems. The Comfort Control Center v1 that was mentioned in this old thread is no longer available. There is a new CCC-II unit which requires different electronics.
Dometic also have a nifty little unit called a Single Zone Thermostat kit (SZT). This kit comes complete with a new digital t/stat and electronic board to run the A/C, but it has to be compatible with your A/C unit.
A call to Dometic customer service will help. They can give you the part numbers that you would need for the conversion. Be aware that the SZT requires 12VDC both positive and negative, but these wires need not be present at the A/C unit.
I have converted quite a lot of newer Dometic units (not on Airstreams though) to the SZT that did not have power at the A/C. The process is fairly simple, but you need 4 wires running from the t/stat to the A/C control box of at least 20 gauge. Positive 12VDC directly to the control box, negative 12VDC to both the control box and t/stat, positive 12VDC from the control box to the t/stat and a communication cable.
PM me if you need more details.
A/C replacement? VWMARTINEZ Furnaces, Heaters, Fireplaces & Air Conditioning 6 03-09-2007 02:14 AM
A/C removal Rob Furnaces, Heaters, Fireplaces & Air Conditioning 14 04-22-2003 06:53 PM
1971 Armstrog A/C uwe Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-06-2002 05:08 PM
Check your aging A/C shroud Jim Clark Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-25-2002 10:30 PM
Mediocre A/C Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-07-2002 07:52 PM
