Old 06-14-2015, 06:24 PM   #1
1990 29' Excella
baltimore , Maryland
A/C starts off strong...
... then gets weak.
I have a 1990 excella. I haven't even looked to see what model the air conditioner is, but does this point to low Freon? Icing up coils?
If so do I need a Freon shot or leak repair?
Is this done from the inside or outside of the airstream?
thanks,
groundhogy
groundhogy is offline   Reply With Quote
Old 06-14-2015, 06:35 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If the coil is freezing over it may low on gas. It can be charged from on the roof but the likely hood you will be able to find and fix a leak is slim.
Low air flow will also cause this problem so make sure the fan is turning at good speed, the coils are not clogged and the filters are clean.
2004 Excursion 4x4
Old 06-14-2015, 07:32 PM   #3
1990 29' Excella
I see the other post...
Engine starts, but won't restart, starter sheared off dalefox Classic Motorhomes 31 08-24-2008 09:45 AM
airstream starts polling customers about the 'dealer service' experience.... 2airishuman Off Topic Forum 12 11-17-2006 10:32 AM
The International Starts and the temp is??? jcanavera WBCCI Rallies & Events 9 07-05-2006 09:28 PM
Airstream and strong winds Devoman Our Community 29 08-30-2005 08:48 AM
Spring Bars Strong Enough? Navigator Hitches, Couplers & Balls 2 10-05-2004 08:48 PM
