We would like to set-up a small window A/C unit in our Bambi II for use in Perry this year. I saw a thread last year, and of course can't find it now, where someone set up an A/C unit in a window with some sort of T-frame stand under the A/C on the outside to help support the A/C unit.
Has anyone done this before? I would be interested in learning more about the specifics of the T-frame stand (or other solutions) and what was used to fill in the gaps in the window opening around the A/C unit.
I don't know about the post, but Fred Coldwell wrote an article for Airstream Life about some people who had done that with their trailers at last year's International. Sorry I don't remember the issue.
Jill and Eric
WBCCI #8689
68 Globetrotter Overlander Underground (Travel and Restoration Blog)
See the Summer 2006 issue of Airstreram Life at page 75. It worked like a charm.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Charter Associate Member FCU
Airstream Life "Old Aluminum Adventures"
Hi,
We have AC installed in our Bambi, but under the couch with ducting. If you look at my husbands thread towards the end... you should find the info for what we did. 63 Bambi Floor Replacement thread by NorCal Bambi.
If you want a non-invasive solution which does not require doing anything to the trailer, look into portable room air conditioners. I use one for emergencies in my house during power outages, and have it available for a loaner if a client's roof unit goes out while waiting for their new unit to arrive. (It gets hot here in FL and my clients can't believe that I offer this service!)
I have a 10K unit that will freeze you out of your trailer if you set the temp low enough.
Just a thought. It also only draws 9.8 amps!
__________________ Lew Farber -Certified Master RV Tech (currently on Forums posting sabbatical, but lurking in the background ) WBCCI #1456 and about to resign!/VAC (assoc) #1456/ AIR # 10325 TAC# OR-1 CHARTER MEMBER: FOUR CORNERS UNIT
The guy who runs GSM has that set up on his 5?. May had been a picture from the Battle of the Bands rally. Bambi's really tight already.
