Old 03-31-2008, 10:01 PM   #1
on the hunt
osolow's Avatar
riverton , Kansas
Send a message via Skype™ to osolow
Cool A/C sealer ?
Ok i have a leak around my A/c,
its were the A/C meets the roof of the A/S. to see it from the inside. i removed the cover and the heat coils then removed the contol panel off the A/C unit you then can see how the unit is sits and is sealed to the body. Well there is a Black plastic tray that the A/C unit sits on and that is then sealed with some grey goop and a lot of it. well that black plastic tray has a crack in it. i was going to try to epoxy the crack to resolve that part, but what is the grey sealer that A/S uses and can i get it at lowes?
osolow is offline   Reply With Quote
Old 03-31-2008, 10:28 PM   #2
_
IF the drip pan is cracked it really should be replaced...
it will leak again, just consider the road motion, flex and vibration up there while the a/s is running...
the gray goop is vulkem/tremco or sikaflex 221, either will work.
Vulkem 116 - Tremco Commercial Sealants & Weatherproofing
http://www.sikaindustry.com/tds-ipd-sf221-ind-us.pdf
http://www.airforums.com/forums/f456...more-7626.html
cheers
2air'
Floor sealer blondie3265 Floor Finishes 12 10-09-2007 08:34 PM
Wheel Well Sealer? bevman Wheel Wells 4 08-31-2007 03:38 PM
we've polished, now what? sealer? happydaze Cleaning, Stripping & Polishing 4 04-17-2007 11:03 PM
Sealer Devoman Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 09-30-2006 08:42 PM
Removing all of sealer Jalina Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 10-16-2004 12:12 PM
