Old 04-02-2005, 03:42 PM   #1
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
A/C scare-weirdness
Greetings.
Today I went up to visit the 19' CCD to kiss, love and fondle, as well as some pre-lim season stuff.
I re-installed the two interstate bats. Checked out furnace, fridge on gas, stove, fans etc.
During this time I also had the AS plugged into my Honda 2000 to give it a workout as well.
I dumbly decided to try out the heat strip on the AC unit. The lights dimmed and I immediately shut off the unit. Everything seemed OK until I (dumbly) decided to try just turning the AC to FAN only.
When I did this, absolutely noth happened, no fan motor, nada...
I checked and reset the circuit breakers, still nothing.
I then unplugged the AS from the Honda, and plugged it into shore power. (I know, I know, but I want to use my little honda). Still no luck.
I took out the filrters in the AC and pulled out my favorite tool, my left hand to see if I wiggled some wires, it might start.
Keep in mind at this point I decided if my AC dies, I'm going to die with it, I was so upset....
I guess ten or fifteen minutes passed, and I re-assembled the AC, as I succumbed to dispair, when I turned the power switch on the AC to fan again, and this time the fan started right up!!!
I let it run on shore power for a few minutes, and then shut it down.
I then (dumbly) plugged the AS back into the Honda and switch on the AC to just fan, and it worked fine. Go figure.
Anyone have this happen. Not the symptoms of severe imbecilism, but with the above AC phnomenom?
I do know that just one 2000 will NOT run the AC compressor.
Thoughs appreciated and welcome.
Love and kisses.
Jon-dumb-than
Sometimes I wish I were living in the stone age. Then I would know I'm the smartest person in the world.
crazylev is offline   Reply With Quote
Old 04-02-2005, 05:18 PM   #2
till's Avatar
Lisle , Illinois
Images: 108
Jonathan,
You may have just kicked out the AC fan motor on thrermal overload. With the time dealy you mentioned it could have had time to cool enough to reset.
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 04-02-2005, 05:28 PM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by crazylev
...I dumbly decided to try out the heat strip on the AC unit. The lights dimmed and I immediately shut off the unit...I do know that just one 2000 will NOT run the AC compressor.
Love and kisses...
Love & kisses? How 'bout a dope slap? Well, you said "thoughts appreciated".
Seriously, it sounds to me like your actions kicked in a self-resetting breaker that did not self-reset by the time you switched over to shore power.
Are you sure that your A/C unit is not a heat pump? i.e. does the compressor run "backwards" to try & warm the place with the aid of the heat strip? If that is the case, I can very easily see your EU2000 not being up to the task. But even if it is not the case, don't sweat it unless it happens on a regular basis.
A firm handshake will do,
Tom
Old 04-03-2005, 09:20 AM   #4
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Tom
You either have a heat pump or a heat strip; never both. The AC is simply reversed to operate in the ehat pump mode.
John W. Irwin
WBCCI #9632
Old 04-03-2005, 09:37 AM   #5
LEV ZEPPELIN
crazylev's Avatar
Chicago , Illinois
Thanks for your replies, fellas.
The reset thing or something like it, was what I thought/hoped it would be but needed the consulation of others.
I'll keep an eye out.
As far as the AC, it's is the standard (11000 btu?) unit and puts out enough heat to warm up the coach a bit for those cool hung-over mornings.
Thanks again.
Pat on the back and hearty handshake.
Jonathan
Old 04-03-2005, 01:09 PM   #6
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Thanks Jonathan!
Ok - so I have a eu2000 - I know it will run my Carrier March III (13,000 btu) FAN (not the AC), I was thinking about getting a heatstrip to quickly heat up the trailer (the furnace takes awhile), and was wondering if it would work with the generator. Guess not, huh?
Handshakes (and a hearty hug)
Marc
Old 04-03-2005, 01:26 PM   #7
TomW's Avatar
1967 26' Overlander
At face value, skipping all the power equations, I find it hard to believe that a 120 vac heatstrip on a 15 or 20 amp breaker will heat your Airstream faster than a 30,000 BTU, gas fired furnace.
Am I missing something?
Tom
Old 04-03-2005, 01:36 PM   #8
Pahaska's Avatar
Hays County , Texas
Marc
The furnace will heat it a lot faster than the heat strip (and without nearly as much noise).
The best a heat strip can do is take away the chill on a chilly morning. Not very fast, at that.
John W. Irwin
WBCCI #9632
Old 04-03-2005, 03:48 PM   #9
1975 Argosy 26
1963 24' Tradewind
hmmm
perhaps I need a new furnace then - I don't get much heat out.
Marc
Old 04-03-2005, 04:10 PM   #10
LEV ZEPPELIN
crazylev's Avatar
Chicago , Illinois
Tom et al.
The furnace will definately be the choice during very cold weather. The heat strip thing in the AC as far as how I use it, is to just take the chill out of the AS, say on a 50 degree morning if I don't want to fire up the furnace. I don't use the heat in the AC as my main source of heat.
If I stand on a wooden box and have the heat strip on, I can even dry my graying, curly hair and look fabulous-ly handsome walking around the campground with the mrs.
Cheers.
Jonathan
Old 04-03-2005, 05:01 PM   #11
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Jonathan
If its a heat strip it will will run until you turn it off. The heat pump will cycle with the thermostat.
Jack
Jack Canavera
STL Mo.
AIR #56
A/C replacement? VWMARTINEZ Furnaces, Heaters, Fireplaces & Air Conditioning 6 03-09-2007 02:14 AM
1971 Armstrog A/C uwe Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-06-2002 05:08 PM
Check your aging A/C shroud Jim Clark Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-25-2002 10:30 PM
Missing piece for Armstrong A/C? 74Tradewind Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-10-2002 04:16 PM
Mediocre A/C Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-07-2002 07:52 PM
