Old 08-04-2012, 05:47 AM   #15
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Great attitude, I see you appreciate the comments of folks here trying to help you.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 08-04-2012, 06:52 AM   #16
SteveH's Avatar
Common Sense , Texas
There are two capacitors up there. One is the start capacitor, and the other is the run capacitor. Since your unit seems to work OK on start up, I would change the run capacitor, and see if that helps. If you have the paperwork on the unit, the capacitors will be designated in there.
Old 08-04-2012, 07:22 AM   #17
HowieE's Avatar
Princeton , New Jersey
Images: 12
Originally Posted by werpknarly View Post
1979 international, original a/c.. it starts up fine, runs 15-20 secs i think... blows COLD air. then trips the breaker.. had the local rv place look at it a couple of years ago. stumped them.. i assume then its doing this while plugged into suffenct electrical supply.
any ideas ?
Best of Luck. We assumed nothing only took what you posted as the bases for our comments.
2004 Excursion 4x4
Old 08-04-2012, 08:46 AM   #18
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
i do wish people would read. three people who know how to test AND changed brakers did that. YES ALL three of us have 30amp service and large short cords.. which capacitor can i change ?
Apologies that I didn't get that from your earlier posts.
Good luck to you.
Alphonse is offline   Reply With Quote
Old 08-05-2012, 05:51 AM   #19
werpknarly's Avatar
1980 31' International
there , Wisconsin
cap
thanks steve, i try to get some time to get under the hood
werpknarly is offline   Reply With Quote
