Old 10-22-2007, 01:10 PM   #1
1972 27' Overlander
cass , Texas
A.C. replacement shroud?
I have a 72 Overlander. My A.C. works great, however the shroud is in bad shape. What's left of it. Will any after market shroud fit? Any suggestions? Thanks
krazeekalvin is offline   Reply With Quote
Old 10-22-2007, 02:15 PM   #2
1971 23' Safari
Atlanta , Georgia
AC cover
If you have an Armstrong unit, check with Andy at Inland RV. I bought one from him a couple of years ago.
silvercomet is offline   Reply With Quote
Old 10-22-2007, 02:15 PM   #3
AC Shroud
The Armstrong AC units were built expressly for Airstream.
There is no "universal" replacement.
However, there is an exact "fiberglass" replacement.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-27-2007, 07:46 AM   #4
1972 27' Overlander
cass , Texas
Thank's Andy. Part #69812? I will get it on my next trip to Ca.
Old 10-27-2007, 08:16 AM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Repair don't replace
Mine was pretty bad. Very brittle, cracks and mssing sections. I repaired it with fiberglass several years ago and it is still going.
Old 10-27-2007, 12:36 PM   #6
AC Shrouds
A word of caution about AC shrouds for Airstream trailers.
If the trailer had a factory installed AC at time of production, then simply having the trailer serial number is all that is needed.
Airstream used 4 different shrouds. 1964 to 1969, 1970 to 1972, 1973 to 1975 and 1976 to 1979.
However, many trailers were built "without" any AC.
The AC, at a later date. was installed by a dealer.
Therefore, as an example, a 1970 to 1972 trailer could have a 1975 or even a 1979 AC unit installed.
It is best to describe the appearance of the shroud that you need, or, for absolute proper identification, look at the photo's in our parts section, of part # 69807, 69812, 69826, or 69831 in our web site, Airstream Innovations at Inland RV Center, Inc. (951) 734-8130
Andy Rogozinski
Inland RV Center
Corona, CA
New a/c shroud!! Chas Furnaces, Heaters, Fireplaces & Air Conditioning 18 01-31-2016 03:26 PM
Replacement shroud for Coleman Delta TX a/c blackbird Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-03-2013 06:55 AM
replacement a/c shroud? roof vents? Dave Cole Furnaces, Heaters, Fireplaces & Air Conditioning 9 12-05-2009 07:00 PM
ac shroud rebel beck Furnaces, Heaters, Fireplaces & Air Conditioning 11 03-12-2006 11:34 AM
