Old 04-12-2011, 12:19 PM   #1
1973 23' Safari
Casselberry , Florida
A/C Replacement
Hi all, I am sort of new to AS. A year ago I got my hands on a 1973 23 ft Safari (with dual axles). I have yet to hit the road, but I am getting close.
My restoration so far includes, replacing the axles and shocks, new rims and tires, replacing the marker lights for LED's and replaced the tail lights cans.
Now the fun begins, the A/C is not working. Currently it came with a Dometic Penguin low profile A/C. It looks like it has been there since the early ninety's.
I was hoping to get some insight as to what would be a good replacement.
Another Dometic Peguin, Carrier low profiles, or any other brand?
thank you for the help in advence,
malopezmo is offline   Reply With Quote
Old 04-12-2011, 01:08 PM   #2
Jim & Mitzi's Avatar
1987 32' Excella
1990 29' Land Yacht
Americus , Alsrural Bristol Tn.
I was able to repair a much older a/c unit.....removed cover, cleaned it up ( including the drain trough ) had it recharged and it's worked for 2 years now. I think I'll have it checked / charged again this year......They usually do not get much use. so they should last many years with a little maintenance. JC
Jim & Mitzi is offline   Reply With Quote
Old 04-12-2011, 03:34 PM   #3
1986 31' Sovereign
Miami , Florida
My Dometic Penguin 13.5 has been pretty bulletproof despite heavy use over three years. Had 1 failure, fixed under warranty in about an hour. So can't complain.
That being said, I'd have somebody look at your existing unit before you commit to replacement. Might be something really simple...
mike
Recommended Toilet Replacement '64 robwok Waste Systems, Tanks & Totes 10 06-22-2014 01:50 PM
Replacement Gold Cone Light for '58 mello mike Lights - Interior & Exterior 7 03-17-2011 11:56 PM
Pls HELP Replacement of Deadbolt in Handle of '90 Elf1 Doors & Locks 8 01-28-2011 09:16 PM
A/C pan replacement Airhouse Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-28-2011 08:16 PM
Water Filter Sump Replacement elzavb Water Heaters, Filters & Pumps 1 01-11-2011 06:12 PM
