Old 07-20-2017, 08:15 AM   #1
1972 31' Sovereign
Carbondale , Illinois
A/C repair
Thanks to all for the heads up on AC fan motors. I replaced the old one with a Marathon Motor 1/6 hp 1075 rpm. The emotorstore carries these in stock. The item number is MANX302. Wire it to the high speed side, lose the low speed side its not needed. If the unit has sat for a while (25yrs in this case) you might need to use a hard start to get it going. Its not a condenser fan motor but it works very well.
solo pilot is offline   Reply With Quote
Old 08-14-2017, 11:41 AM   #2
Bend , Oregon
Looks like this might be an Armstrong ac unit is that correct?
derf is offline   Reply With Quote
To repair or not to repair Wildwash Trailer Values 10 06-09-2017 04:29 PM
Dash Repair Questions JW84345 Airstream Motorhome Forums 15 07-15-2012 09:59 PM
Plastic bathroom components crack repair with 3M 4240 semi-rigid plastic repair kit Top Upholstery, Blinds, Walls & Interior Finishes 1 05-09-2011 08:11 PM
1961 Dometic Refrigerator - Best Repair Shop? Andy R Refrigerators 18 03-21-2011 09:07 PM
shop repair of 1970s rear frame separation (non elephant ears repair) RV shop review simonhanbury Repairing/Replacing Floor &/or Frame 49 06-24-2008 10:16 AM
