Old 10-13-2007, 08:22 PM   #1
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
A/C relocation
My 63 19' Gt has a coleman A/C that PO mounted on the rear 14x14 vent.I would like to move it forward between the front and rear vents. I assume that I would need to reinforce the roof after cutting a new hole for the A/C.Is this operation advisable? Thanks...........
Cochese is offline   Reply With Quote
Old 10-13-2007, 09:35 PM   #2
Images: 59
I mounted a Penguin between the vents in my '59 Tradewind. You have less length, but only two vents to worry about instead of three.
Mounting the A/C between the vents will center it above the axle, which is a good thing. You want to pick a location between two ribs, which are easy to find by looking for vertical rivet lines. You might want to remove the interior wall sheeting on one side to make it easier to run the power and drain line. The drain line will probably end up in a wheel well.
The instructions that come with the unit will tell you to use wood to frame the space between the ribs. I used aluminum channel, which I think is less likely to rot. It's not a hard project.
And you will be pleased with the results. Your Airstream will look happier with the A/C unit centered over the axle.
markdoane is online now   Reply With Quote
Old 10-13-2007, 09:44 PM   #3
2005 25' International CCD
1954 22' Flying Cloud
1957 22' Flying Cloud
Simi Valley , California
Originally Posted by markdoane
\\ SNIP //
I mounted mine from the rear.
bob
Kevbo10 is offline   Reply With Quote
Old 10-14-2007, 10:03 AM   #4
krikles's Avatar
1965 17' Caravel
west hills , California
Mine also came with an ugly big a/c right at the rear. I tossed it, put in a Fantastic Fan in it's spot and put a Carrier lo profile in the center. Looks so much better!!!
krikles is offline   Reply With Quote
Old 10-14-2007, 04:24 PM   #5
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Are any peices needed to sandwhich between the ext. & int. alum. for support?
Old 10-14-2007, 04:30 PM   #6
Images: 59
Yes, you need either wood, aluminum, fiberglass, or something structural to sandwich between the inside and outside to frame the 14" square opening. The stronger the better.
The pieces need to be supported and attached to the structural ribs.
Furnace vent relocation. Safari Tim Furnaces, Heaters, Fireplaces & Air Conditioning 0 01-22-2005 08:37 PM
Converter relocation FrankR Batteries, Univolts, Converters & Inverters 0 07-31-2002 09:30 AM
