Old 07-14-2015, 11:28 AM   #1
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
A/C recommendations
Reluctantly considering adding a roof A/C unit to my 55 FC. I hate the way they look on vintage trailers but am beginning to think it may be the best solution. Anyone else done this on a 50's trailer?
What is the lowest profile unit currently available?
Will it fit in my existing vent opening?
I am guessing it is not pre-wired for AC power...
How do I handle the considensate?
Thanks in advance!
BambiTex is offline   Reply With Quote
Old 07-14-2015, 01:10 PM   #2
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
You may want to look up Kevin Katz here on the Forums and send him a PM. He has installed an A/C in his 1965 Caravel and might have some insight.
Cannonball is offline   Reply With Quote
Old 07-14-2015, 01:20 PM   #3
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
I know Kevin. 60's trailers are generally pre-wired and have standard 14" openings. Not sure the same is true for 50's trailers...
Old 07-14-2015, 01:55 PM   #4
submariner's Avatar
1948 22' Liner
1989 34' Limited
long beach , Mississippi
i am rebuilding a 48 Liner and it will receive a self contained Dometic Truck AC, which mounts inside one of the beds. Heat is discharged through a vent on the bottom and the cold air is plumbed to the top of the cabinet next to the bed.
I know those units are very expensive, but we did not want the look of an AC on the top of a Vintage camper....
Stefan
Resurrecting one Airstream at the time..
maybe one day i save them all
submariner is offline   Reply With Quote
Old 07-14-2015, 02:12 PM   #5
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
How expensive?
What model?
Old 07-14-2015, 03:11 PM   #6
submariner's Avatar
1948 22' Liner
1989 34' Limited
dometic model Blizzard self contained unit, ASCDQ10 with 1.5KW electric heat, remote thermostat and control, interface cable, $2300.-
Stefan
Old 07-15-2015, 06:05 AM   #7
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Retailer?
Old 07-15-2015, 06:42 AM   #8
submariner's Avatar
1948 22' Liner
1989 34' Limited
i get it locally through our dometic rep that provides equipment for the company i work for. But there are several truck places, that sells it. check on dometic page for a retailer in your area :-)
Stefan
Old 07-15-2015, 06:42 AM   #9
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Just curious, how are those truck units on noise level inside compared to a roof unit?
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 07-15-2015, 06:44 AM   #10
submariner's Avatar
1948 22' Liner
1989 34' Limited
i have not installed it yet, soi can not comment, but i do know , those units are installed inside the sleeper of a truck, so they cant be very loud.
Stefan
Old 07-15-2015, 07:01 AM   #11
Cardinal283's Avatar
Dallas , Texas
I've got an AC tech who's going to take a 15k btu window unit and convert it to a split unit with the condenser venting through the floor and the evaporator under the bed in the rear. Cool air will be ducted to a center trunk line on the ceiling.
Cardinal283 is offline   Reply With Quote
Old 07-15-2015, 07:25 AM   #12
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Interesting idea
Cost?
Please PM me contact info for AC Tech. I am in Houston.
Old 07-15-2015, 07:26 AM   #13
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
What about roof mount a "modern" unit then make or have made, a metal cover to "replicate" the retro look?
Peace and Blessings..
Channing
WBCCI# 30676
Yellowstone / Grand Teton Campground Recommendations JaceBeck On The Road... 13 07-26-2006 09:37 AM
air conditioner recommendations Tin Hut Our Community 11 09-05-2003 04:30 PM
Drain Fitting conversion? Recommendations? Jabba Waste Systems, Tanks & Totes 3 07-11-2003 05:30 PM
shop recommendations in K.C. kc airstreamer Commercial Listings 0 05-18-2003 12:34 AM
de-humidifier recommendations dpope 2003 Safari 3 04-07-2003 03:08 PM
