Old 06-19-2011, 05:01 PM   #1
Davis's Avatar
1996 34' Excella
Americus , Georgia
A/C Question ?
I have a 1991 34ft trailer with the original 13.5 Penguin A/C on it. This past weekend it started leaking water inside the trailer. Could that be caused from the drain lines being blocked ? Or something else ? Thanks Davis
1991 Airstream Excella 1000 34ft (SOLD)
1994 Chevrolet Crew Cab dually 2WD 6.5td
2005 Chevrolet Suburban LT 1500 2WD 5.3
WBCCI # 10219 Georgia Unit
AIR # 5131
Davis is offline   Reply With Quote
Old 06-19-2011, 05:17 PM   #2
Mexray's Avatar
1978 28' Ambassador
Morada , California
A plugged drain line may indeed be the cause...
You can probably remove the AC units cover on the roof to get to the 'inlet' of the drain - it could be the connection between the line and the AC's drain is detached, rotted, etc...
If you can get to the drain on the roof, you may then be able to purge the line with low pressure water from the garden hose...or try purging from the 'outlet' end of the drain line in the same manner while someone checks up at the AC unit on the roof to see if there's a clear flow....
If the drain line is detached or damaged INSIDE the roof panels, some other method than the garden hose should be used - maybe low pressure air from a compressor, for example...
As I recall when I replaced our AC unit, the drain line was accessible from inside the trailer with the AC panel removed...
Luckily, the Carrier AC unit we used as a replacement doesn't require a drain line - there's a collection pan built into the unit that has airflow directed to it to evaporate the moisture...It's worked fine so far, but we've not had to run it 24/7 as is required in the hot & humid South...
Ray & Pat; Morada, CA
Old 06-19-2011, 05:22 PM   #3
Bambi_Bandit's Avatar
2008 27' International FB
1964 19' Globetrotter
1955 26' Cruiser Overlander
Images: 12
or a cracked drain pan. Let's hope its just a clogged drain line...
Kevin & Prim Li
Bandit the Siberian Husky (RIP) & "G" the Min-Pin (RIP)
Cosmo the Custom 2008 27FB Intl CCD
Maxwell the 1964 Globe Trotter
Name TBD the 1955 Overlander
WBCCI # 6155
AIR # 6155
2nd love - 2006 28' Safari LS
1st love - 2004 19' CCD Bambi
Bambi_Bandit is offline   Reply With Quote
Old 06-20-2011, 07:28 PM   #4
Davis's Avatar
1996 34' Excella
Americus , Georgia
Thanks for the advice. I looked today and the outlet on the drain is cracked so I will seal it and hope that holds.
AIR # 5131
Thinking of going Dual A/C Mr & Mrs S Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-04-2011 05:48 AM
Steel / Aluminum wheel question polarlyse Wheels, Hubs & Bearings 12 05-29-2011 07:49 PM
1980 Caravelle axle question Seymour Axles 5 05-14-2011 08:28 PM
EVAP Canister? question 8rmesse Classic Motorhomes 23 04-24-2011 06:41 AM
Blasphemous question woytovich General Repair Forum 15 04-09-2011 08:36 AM
