Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 07-15-2006, 07:38 PM   #1
gowyn's Avatar
Profile:  2007 27' Safari FB SE
London , ontario
A/C Question
Hi all.
Have a question regarding the a/c in my 2005 19' Bambi. Is it "normal" for the a/c not to kick in until the thermostat is turned past 6 on the 0-7 scale?
Even when it's cranked to 7 the compressor will only run for a couple of minutes then cyles off. Compressor makes nice cold air, fan runs fine. Incoming voltage is 115v plus, just seems like the thermostat is set too high.
Outside temp was 28c, I believe it's the Penguin low profile a/c unit.
Any thoughts?
gowyn is offline   Reply With Quote
A/C replacement? VWMARTINEZ Furnaces, Heaters, Fireplaces & Air Conditioning 6 03-09-2007 02:14 AM
A/C removal Rob Furnaces, Heaters, Fireplaces & Air Conditioning 14 04-22-2003 06:53 PM
1971 Armstrog A/C uwe Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-06-2002 05:08 PM
Missing piece for Armstrong A/C? 74Tradewind Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-10-2002 04:16 PM
Mediocre A/C Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-07-2002 07:52 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
