10-06-2004, 11:37 AM
A/C question ???
I have a Duo-Therm 15K Brisk air unit I want to use to replace the Coleman on my 1979 Motorhome.
I am looking for the pan to fit it to the Airstream, also I am trying to find out if I do put this on will the drain line be used or will the water just run down the side?
Also if this swap does work, I will want to sell my Coleman complete and was wondering what years it would fit being that it is on a 1979 now.
10-06-2004, 01:09 PM
2004 30' Classic Slideout
Fenton
, Missouri
The Duo-Therm Penguin 15K unit does have a drip pan. I'm not sure if the Brisk-Air does. You might give Dometic a call and see what they say.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
10-06-2004, 01:56 PM
Jack
Thanks for the reply!
But mabye someone here in the forums has a brisk air and can answer from experiance.
PS: I dont have a Penguin or I would not be asking this question.
10-06-2004, 03:24 PM
Fenton
, Missouri
I wasn't sure if you had made a purchase yet which was why I brought up the alternative.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
10-06-2004, 06:31 PM
Corona
Duotherm or Dometic, do not have drip pans.
The only drip pans ever used were all made by Airstream, and they through, a dealer are your only source.
The only current drip pan is for the Dometic "Penguin" units.
They can be made however from an aluminum sheet if someone so chooses.
05-17-2010, 11:56 AM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
Old thread same question...
Andy...or anyone....I have a Dometic Brisk Air AC on the Flying Cloud (model 57915-622) Does this have a drip pan? If not...where can I find one or get the dimensions to build one?
Thanks.
RC
05-17-2010, 01:33 PM
1953 32' Liner
1955 22' Safari
Valley View
just some more research
I hope this helps someone else out there.
05-19-2010, 08:00 AM
Corona
Great drawing.
But, you will have to install a drain line to the pan.
Andy 9.7
