Old 07-05-2015, 02:00 PM   #1
Living Riveted
2014 19' Flying Cloud
Carnegie , Pennsylvania
A/C Question
2014 Flying Cloud, 19 feet. A/C seems to not be cooling down the unit...any idea why? Air feels more like fan than A/C. We're parked at a campground and connected to 30A hookup, no other issues. High temp today is 80 degrees F.
Arnoldjeff is offline   Reply With Quote
Old 07-05-2015, 02:37 PM   #2
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
Have you checked your fuses?
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Old 07-05-2015, 02:55 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Been running an hour, any better?
MICHAEL
Old 07-05-2015, 03:11 PM   #4
Living Riveted
No better, temp has actually gone up a few degrees in the unit. No breakers tripped and fuses all good. I just set it to cool and adjusted the temp to 72, did I miss a step?
Old 07-05-2015, 03:58 PM   #5
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
A trip to a service center is probably in order....
Do you hear the compressor running? Set it to fan only and see if it gets quieter. But either way, I suspect you are going to need service. If the compressor is running, you may have a refrigerant leak. If it is not, the leak may be old enough or bad enough that the low pressure switch is keeping the compressor off or the expansion valve is plugged and the high pressure switch is. Check your filters. It is amazing to me how quickly ours get stopped up. If you can see the evaporator fins when you pull the filters see if they are cold.
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
