Old 06-28-2011, 01:38 PM   #1
RichWoodward's Avatar
1990 29' Excella
Lexington , North Carolina
A/C Pops Breaker
Yesterday I went out, turned the A/C on and "pop" went the breaker in the rear panel of the trailer. I am hooked into a dedicated 30 Amp plug and have used it numerous times in the past. I'm trying to figure out what is going on. The last time I used the A/C was probably 2-3 weeks ago. The fan works; just when I try to go to the A/C does it pop. Is it low on freon? It is, admittedly, a LOT hotter than the last time I tried it.
Thanks for any help
RichWoodward is offline   Reply With Quote
Old 06-28-2011, 01:46 PM   #2
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Rich,
Ours popped, too, once in a while during a recent trip. Temp. outside should not make a difference, but what ELSE is running at the same time might. Could not use it and make toast at the same time, for instance. Give it a try when it's the only thing running, eh?
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 06-28-2011, 01:52 PM   #3
bassfiddler's Avatar
1971 23' Safari
Lilburn , Georgia
It's possible the circuit breaker is bad but probably more likely there's a problem with the compressor on the AC unit. My original AC would do the same thing and after determining it wasn't the breaker I bit the bullet and replaced the 40 year old AC. Obviously your is much newer than that but still 20 years is pretty long time...
bassfiddler is offline   Reply With Quote
Old 06-28-2011, 02:06 PM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
Which breaker? The 30a main or the 20a breaker for the A/C unit itself?
Old 06-28-2011, 02:09 PM   #5
1990 29' Excella
The little one, inside the trailer. Everything else works. When I kick the switch over to A/C, the motor pulls down, labors, then pops.
Old 06-28-2011, 02:12 PM   #6
1990 29' Excella
Is it possible that I am low on freon? Would that make the thing labor enough to throw the breaker?
Old 06-28-2011, 02:25 PM   #7
1971 23' Safari
Lilburn , Georgia
I wouldn't think so. I just had my unit at my house serviced because it wasn't blowing cold air. Turns out it was low on freon, but the outside condensing unit was running fine. Sounds like it's motor or compressor related to me...
Old 06-28-2011, 03:06 PM   #8
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
OK, back to Jammer's question, of the little ones inside the trailer, is it:
You should have a 30a main breaker in the breaker box inside the trailer that controls all the power to the Airstream. You will also have a 20a breaker just for the AC. You have both in your breaker box. Which is tripping?
Sometimes breakers just get old. I replaced all of mine. The GFCI (the one with the "Test" button) one is kind of pricey, but the rest are not expensive and are easily available at hardware stores.
Vaughan
Old 06-28-2011, 04:09 PM   #9
1990 29' Excella
Sorry, it is the 20a breaker. The main breaker is OK as the rest of the power stays on. Whenever I turn just the fan on, on the unit, it runs, then when I flip it over to AC the motor labors for 5-6 seconds then the breaker blows. If I try to flip it back to on, it refuses until I turn the AC back to fan only. Again, the last time I used the AC, several weeks ago, everything was fine.
This appears to be a Square D box, and the AC breaker is one of those little split breakers; any reason that the breaker might be suspect? I wouldn't think so but I am absolutely NOT an electrician.
Old 06-28-2011, 04:20 PM   #10
Wise Elder
Jammer's Avatar
2010 30' Classic
The most likely causes are the starting relay and starting capacitor. I would replace both before trying anything else. If the relays are expensive or hard to find you could try just replacing the capacitor.
Old 06-28-2011, 06:21 PM   #11
1990 29' Excella
Thanks. I hate to be stupid but how do I get to, and identify, the relay and/or capacitor. Do I go in through the top or the bottom?
Old 06-29-2011, 10:33 AM   #12
Wise Elder
Jammer's Avatar
2010 30' Classic
I don't know what make and model A/C you have but all of them have the capacitor somewhere under the top shroud, usually in a little metal box with 5 or 6 wires coming out of it.
Old 06-29-2011, 10:58 AM   #13
macofpei's Avatar
2003 30' Classic
Stratford , Prince Edward Island
Send a message via Yahoo to macofpei Send a message via Skype™ to macofpei
You could also be not getting full shore power. It might be worth checking the power connection for voltage and if low, it will caus the 20 amp breaker to pop.
Are you at a campground or plugged into your own house power supply?
Mac from PEI
Canada
WBCCI #4782
"Southern Belle"
'03 Classic 30'
'10 Toyota CrewMax
macofpei is offline   Reply With Quote
Old 06-29-2011, 02:19 PM   #14
2011 31' Classic
Ah, so right Mac! We plugged in at a poor camp one time and EVERYONE was complaining about the low voltage of the power plugs. Could always be that.
No Power To A/C (power at breaker) vhariable Electrical - Systems, Generators, Batteries & Solar 3 06-28-2011 05:54 PM
Thinking of going Dual A/C Mr & Mrs S Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-04-2011 05:48 AM
A/C Cover...how does it come apart? KyMoonshine Furnaces, Heaters, Fireplaces & Air Conditioning 6 05-10-2011 05:59 PM
Charge line breaker stuck open AirHome Batteries, Univolts, Converters & Inverters 3 04-13-2011 10:18 AM
A/C pan replacement Airhouse Furnaces, Heaters, Fireplaces & Air Conditioning 8 01-28-2011 07:16 PM
